ALS/SAS Routines in 90550701
Old Sep 23, 2019 | 02:53 AM
rjwkerkhof's Avatar
As a test I am running a E7 ecu in my E6 with the Tephra 90550701 V7 rom. ALS tables are in my xml and setup the same is in my original E6 ecu, did swap pin 6 to pin 53 in order to have working ALS/SAS. However ALS/SAS does not seem to activate, even the logs show that fuel (inj duty / ipw) is shut down 1 sec after throttle release. When I apply a ground to the wrie at pin 53 on idle the solenoid activates and the car starts to hunt so my hardware is still working properly.
Can it be that there is no ALS/SAS routine in the Tephra 90550701 V7 rom or do others have no issues with getting ALS/SAS to operate with this ROM
Anyone else who has ALS/SAS working on the Tephra 90550701 V7 rom?
Thanks in advance,
Roy
Old Sep 23, 2019 | 09:36 PM
foxbat's Avatar
Thanks in advance,
Roy
I recall having an issue with SAS activating with a 9055 V7 rom. Try a V5 rom & see how it goes.
Old Sep 25, 2019 | 04:13 AM
rjwkerkhof's Avatar
Hi Foxbat,
Have you had the ALS/SAS operating on the V5 ROM. I did a quick disassembly of both the V5 & V7 ROM but was not able to find differences in the SAS routine so far. Also the subroutine for SAS seems to be called in both ROMS.
Old Sep 25, 2019 | 01:50 PM
foxbat's Avatar
Hi Foxbat,
Yes, I used a v5 9055 rom E7 ECU on an Evo 4 with sas activated & the results were impressive producing very loud bangs. However, & for some weird reason, activating sas on an actual E7 rather than E4/5/6 produces mild bangs only.
Old Sep 25, 2019 | 01:52 PM
Biggiesacks's Avatar
maybe you need to look into the injector fuel cut routine. Perhaps it works a little different on a SAS enabled car.
Old Sep 26, 2019 | 12:00 AM
rjwkerkhof's Avatar
Thanks for the information Foxbat, The case with the actual E7 and SAS is most likely due to the EGR, most say the EGR needs to be blanked off in order to have good operating SAS.
Old Sep 26, 2019 | 12:27 AM
3VOLUTIONIST's Avatar
My Evo 3 engine & SAS hardware has no EGR components and I get the same instantaneous Decel fuel cut with the ALS routines enabled.
Old Sep 26, 2019 | 01:27 AM
foxbat's Avatar
Even with EGR blanked, I never manged decent bangs when sas is activated.
Old Sep 26, 2019 | 01:55 AM
rjwkerkhof's Avatar
Was this with the V5 ROM as well?
Old Sep 26, 2019 | 02:00 AM
I believe so. I did have the car running on the v5 ROM a while back, and I don't recall the ALS working, because I do recall trying to fix the decel fuel cut always cutting the fuel instantly.
Old Oct 2, 2019 | 04:09 AM
rjwkerkhof's Avatar
Well, I think I might have found something interesting, in the picture below I have made a screenshot of 2 dissassemblys of the ALS routines: left side is ROM id:98640014 E7 JDM ROM, right side is 90550001 E7 EDM ROM and code looks the same as in the Tephra V7 ROM.
As you can see for the 90550001 ROM there is a extra RTS and NOP command at the end of the code, can someone tell if they might be the cause of the ALS not on the 90550001 ROM and the Tephra V7 ROM.
RTS seems to be: Return from subroutine --> go back to main routine which called this subroutine
Thanks a lot!
Old Oct 3, 2019 | 12:15 AM
foxbat's Avatar
Have you made a comparison between v5 & v7 (9055)?
Old Oct 3, 2019 | 11:27 AM
Coming at it from the other direction, this is what I have been able to find.
I Traced the Gate 1 of IC32 Back to the Chip. It's a straight shot, there aren't any passives in series. As best I can tell, it leads to Chip Pin 134 (position 30 from the left)
Another Angle
This is what I found from the manual.
Pin 134 corresponds to Port J8
The DR bit is the one that toggles the pin.
Hopefully this is helpful. I have verified this info as best I can with the resources I have. If someone else could replicate these findings that would be great.
Old Oct 3, 2019 | 02:34 PM
3gturbo's Avatar
any chance I can get someone to send me that rom i donated but tephra doesnt respond.
Old Oct 4, 2019 | 01:03 AM
rjwkerkhof's Avatar
Another Angle
This is helpfull indeed, now I need to check the code as well. I will try to trace it the same as you on my pcb at home as well.
Rico8638
Lancer Engine Management / Tuning Forums
Jan 29, 2022 04:57 PM
Burz666
May 12, 2013 12:35 PM
wcassar
May 24, 2012 07:12 AM
Appauldd
Apr 13, 2011 01:37 PM
silverghost
Aug 30, 2007 12:05 PM
