ecuflash problem
Old May 23, 2012 | 11:22 AM
wcassar's Avatar
ecuflash problem
Hi all I am trying to edit the ecu map of my evo 7.
I have read the map from the ecu......resulting in a readimage*.
The problem is here, only the immobilizer code and the initial code are visible.
The other timing, fuel maps etc are all not visible.
what could be the problem?
regards
Old May 23, 2012 | 11:39 AM
RoadSpike's Avatar
You lack a defintion file for the rom. The id of the rom should be visible search google with the id.xml and get a proper definition for your car.
Old May 23, 2012 | 01:31 PM
wcassar's Avatar
what is the id exactly? immobilizer one? or identity id..........identity is 0100 and immobilizer is FFFF currently
only those to table can be accessable.
regards
Old May 23, 2012 | 01:36 PM
RoadSpike's Avatar
regards
Should have a rom info spot at the top of the left column with a internal id:
For example an evo 8 can look like this 94170015
Also when you open the rom the middle of the program is a running log it should say what it is there as well. Here's a snipet.
[13:35:15.797] 94170015 (72 tables) inheriting evo7base (73 tables)
[13:35:15.797] 94170715 (45 tables) inheriting 94170015 (74 tables)
[13:35:15.797] 262144 byte image read.
Old May 23, 2012 | 06:30 PM
wcassar's Avatar
I have found the xml and rom which match mt internal id.
please find attached.....
now what do i have to do?
regards
Old May 23, 2012 | 07:20 PM
jakermeister's Avatar
Download the definition and put it in the "rommetadata" under the "lancer" section in the PROGRAM FILES. It explains it better in the master definition thread.
Old May 23, 2012 | 11:00 PM
RoadSpike's Avatar
While that would work his case is an evo so it would be better to slap it under the evo folder.
(program files folder)/openecu/ecuflash/rometadata/mitsubishi/evo/ (put file)
Old May 24, 2012 | 07:12 AM
I forgot there was a evo folder.
Hiram6g74
Apr 13, 2017 08:59 PM
GST Motorsports
113
Feb 14, 2017 06:09 AM
tephra
Jul 25, 2016 02:21 PM
Deepnine
Jul 8, 2009 05:02 AM
500whp.com
40
May 18, 2006 10:29 AM
