ECUunlocker - what does it change?
Old Nov 22, 2019 | 02:31 AM
ROB-80E's Avatar
Hey guys,
Just wondering if anyone is able to elaborate on what ECUunlocker actually changes.
So what I know is that it will find the init key of an ECU that doesn't have a default key. But does it save or change anything on a PC/laptop to remember that key?
Here's the example:
Using laptop 1, I open ECUunlocker and then ECUflash to read a "locked" ECU. Closed ECUflash and restarted the laptop. Opened ECUflash without running ECUunlocker, and ECUflash will now read the ECU.
I use laptop 2 after using laptop 1, open ECUflash and the ECU cannot be read.
So nothing has changed on the ECU, so how can laptop 1 now know what init key to use? Something must have been saved/changed on laptop 1.
Any ideas? Cheers!!
Old Nov 22, 2019 | 06:34 AM
Project_Broke's Avatar
I've had some odd issues with ECUflash and what I would consider it's cache of sorts. Data not saving, and saving when not told.
Ultimately, unless you change the hex code to the correct data and save the rom, I don't think it would work on anything but the PC ECUunlocker ran on.
Old Nov 23, 2019 | 03:24 PM
ROB-80E's Avatar
Cheers mate. Any idea where ECUflash caches it's data in Windows?
EvoLLBlue8
Dec 13, 2013 10:02 PM
napado
13
Mar 31, 2010 01:49 AM
rolly1818
Nov 25, 2008 05:09 AM
boony
Nov 30, 2006 01:28 PM
MalibuJack
Aug 23, 2006 04:14 AM
