aem wideband
Old Dec 10, 2019 | 12:35 PM
wordword's Avatar
aem wideband
so i recently bought an evo 4 with evo 7 ecu with tephra v7 90550701. i trying to sort out 2 problems, my car never goes into closed loop and the wideband does not read correctly, this is what my eval is, 10.00+(16.99-10.00)*x/255.
also i would like to start with an evo 8 timing map, as im getting strange knock on part throttle low load
any help would be appreciated
File Type: zip
Old Dec 12, 2019 | 01:51 AM
jozy's Avatar
wideband? reading via evoscan?
why never going into closed loop? coolant temp not met? post start o2 control parameters wrong?
Old Dec 12, 2019 | 07:12 PM
wordword's Avatar
evo scan is reading wideband but its off like 1 afr off.
about closed loop, i know the coolant temp is met, ill check o2 control parameters
Old Dec 15, 2019 | 04:05 AM
audiofan's Avatar
You can modify the formula to meet the wideband!
Always on open loop could be the Tephra options, there is one to keep always on open loop, check that
Old Dec 15, 2019 | 10:27 AM
wordword's Avatar
im not seeing that option. but my o2 sensor voltage is around 0.133 and bearly moves. ill try another o2 sensor
Old Dec 16, 2019 | 03:44 PM
audiofan's Avatar
Go to ecu Periphery0
allow closed loop, if it is not allowed (0) then you are set always on open loop
Old Dec 25, 2019 | 11:36 AM
todd6027's Avatar
if you have front o2 heater turned off in periphery trims wont update , as the 4 doesnt use a 4 wire o2 so they turn it off in the periphery bit 14 faa , id usually wire in a 4 wire o2 sensor , for heater wires 12v to one wire (you can use the same wire as radio suppesor usually bolted to cam cover) and other heater wire goes to pin 60 , dont try enable open loop method its a disaster
burner67
Lancer Aftermarket Forced Induction Tech
Jul 8, 2011 11:20 AM
J8dailo
10
Jan 5, 2009 04:40 PM
the1andonlyE
Aug 10, 2007 03:58 PM
MalibuJack
Mar 11, 2007 12:00 PM
mooreboost
21
Apr 10, 2005 07:27 PM
