How do you disable/remove cels from the ecu with ecuflash?
Use EvoScan to read the diagnostic trouble code (DTC) and turn the check engine light (CEL) off. You can display your DTC code(s) in the lower right hand corner. You can also delete the code(s) from there.
Use ECUFlash to change the bit to 0 corresponding to the code you want to disable in the Periphery.
