Remove CEL with ECUflash/EVOscan?
Old Sep 4, 2016 | 05:03 PM
SPOOLIGAN's Avatar
Hello everyone. Been battling an annoying problem for awhile and trying to figure it out. I have a 1G DSM with an Evo 8 ECU. I'm using the 9653 Tephro Mods ROM. How do I delete ALL CEL's?
I cleared them once via EVOscan. Now if I check my codes, there are none. But the CEL still remains on. I want to be able to use the CEL on Knock feature but with the CEL always on, it prevents me from doing so.
Old Sep 6, 2016 | 08:57 PM
ReidFletcher's Avatar
Would suggest posting this in the "Engine management/Ecuflash" subforum.
Old Sep 7, 2016 | 07:04 PM
Evo_Goodness's Avatar
What is causing the cel is it because of a problem or because you are running a 1gdsm with an evo 8 ecu is there a specific code with the cel ?
Old Sep 8, 2016 | 12:07 PM
heel2toe's Avatar
If you dont have any codes then I dont understand why your CEL would still be on? But FWIW you can still have your CEL flash with your car having a CEL. It will do just that, flash instead of staying solid the whole time.
Jakeg97
133
Jul 30, 2021 08:19 AM
TxFAkuma
Dec 6, 2017 08:53 AM
Spinsall4
Nov 27, 2007 09:50 AM
