Idle Timinng Compensation maps - 56910009
Stock roms can be found below. The 0007 values can most likely be transferred over if it is stock.
http://norcalmotorsports.org/users/b...ch/ROMs/Evo10/
Here you go.
(Warning: Not proofed. Use it at your own risk.)
<scaling name="IgnitionCompensation" units="x" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big"/>
<scaling name="Idle RPM Offset" units="RPM diff" toexpr="(32768-x)*1000/256" frexpr="32768-(x*256/1000)" format="%.0f" min="-200" max="200" inc="4" storagetype="uint16" endian="big"/>
<table name="Idle Timing Compensation 1.1" category="Idle" address="5f894" type="2D" swapxy="false" scaling="IgnitionCompensation">
<table name="RPM" address="630b6" type="Y Axis" elements="29" scaling="Idle RPM Offset"/>
</table>
<table name="Idle Timing Compensation 1.2" category="Idle" address="5f8b6" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
<table name="Idle Timing Compensation 2.1" category="Idle" address="5f8d8" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
<table name="Idle Timing Compensation 2.2" category="Idle" address="5f8fa" type="2D" swapxy="false" scaling="IgnitionCompensation">
</table>
</table>
</table>
</table>
</table>
jwick76
Lancer Engine Management / Tuning Forums
Oct 10, 2011 11:26 AM
Clipse3GT
Oct 15, 2009 09:16 PM
