ECUFLASH: Which table/map do you modify to raise your idle rpm?
I want to raise my idle RPM's to 1000rpm from the stock 750rpm. I am wondering if you modify the coolant vs idle table (there is 9) or you modify the target idle tables (there is 15) do you change each table to 1000rpm once the coolant is at temp. or at 72/88*C on the table.
I know the car will stay at around 1500 rpm and slowly start to lower it's rpm to the target value which around 700 rpm stock.
Any info is great!
Any info is great!
I figured it out thanks to some help.
To change idle, change all Target Idle tabes to the desired value and change all Coolant Vs Idle tables to desired values in the 70 and 80C brackets.
