error sending kernel size
Old Jun 23, 2020 | 01:46 PM
professor_jonny's Avatar
I'm getting an error trying to read the transmission rom from my ECU, I have successfully read the engine rom but when I switch my boot pin on to TCU pin of the 12 pin diag connector I get the below info in ecuflash:
[08:15:05.672] using metadata XML ID read_evo5 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[08:15:10.309] using metadata XML ID read_evo5 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[08:15:10.325] J2534 API Version: 04.04
[08:15:10.325] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[08:15:10.325] Device Firmware Version: 1.17.4877
[08:15:10.325] Device Serial Number: TA44lQGt
[08:15:12.501] sending init sequence 2
[08:15:12.501] got 0x10 response instead of 0x11
[08:15:12.501] sending init sequence 3
[08:15:12.861] entering bootloader
[08:15:12.861] sending kernel size (2029)
[08:15:12.861] error sending kernel size
[08:15:12.861] interface close
Old Jun 24, 2020 | 04:03 AM
From looking at the Car Hackers handbook 0x10 means the ECU has entered diagnostics instead of preforming a remote reset 0x11
If so either I'm doing something wrong or it is locked/ or reading is not supported with ecuflash.
http://opengarages.org/handbook/ebook/
holydevil
Oct 27, 2024 04:53 AM
neddludd
Jun 12, 2020 05:37 AM
bluelancer20028
Feb 16, 2010 09:44 PM
espritv8
Sep 8, 2006 09:08 AM
