Do the Tephra v7 VE tables change load cells for timing?
Old Aug 30, 2020 | 09:38 AM
EVO8LTW's Avatar
When you adjust fueling using the MAP VE or RPM VE tables, does that shift the load for timing purposes? For example, if your RPM VE is 110% at 4000 rpm, does that mean that at that RPM, your loads at the same KPA value will be higher in timing table, so you’ll get a lower timing value than what 1byte load would suggest in your logs? I have noticed my logs not always following my timing table and I think this might be the issue. Not sure if I’m making sense? I watched a BD Alchemist video on YouTube that suggested this was the case and I never understood that. Been running SD for 10 years.
Tuxevo
Nov 25, 2014 08:00 AM
roger smith
Aug 31, 2009 10:07 PM
recompile
Mar 24, 2009 02:12 PM
kf6ytc
Aug 3, 2006 07:30 AM
