Ecu flash and Vag cable
Old Dec 29, 2020 | 11:10 PM
Rick2020's Avatar
5 Year Member
I've got the Evo 6 ecu and I'm waiting on some injectors to fit in my evo 4 . Apart from adding a wire to pin 79 can I use a Vag cable? If that's the case is there anything else I need to do or require
kind regards
Old Dec 30, 2020 | 07:06 PM
Rick2020's Avatar
5 Year Member
I've had a look round today at the obd port and there is nothing there or around it to fit an adapter for flashing.i no I have to fit the wire at pin 79 but where do I put this wire from pin 79 to?
Someone must no something
Old Dec 31, 2020 | 08:41 AM
CDrinkH2O's Avatar
@Rick2020 They do, and it is all documented in this forum. A simple Google search provides many answers to your questions. Here is one for you to read: https://www.evolutionm.net/forums/ec...ble-right.html
Old Dec 31, 2020 | 11:26 AM
Rick2020's Avatar
5 Year Member
Hi I've seen that post before. One question still remains that isnt spoke about. Pin 79 yes I get you have to put a wire there. But where does the wire go to afterwards? .The vag cable doesn't have anything for the wire to plug in to
Old Jan 1, 2021 | 08:58 AM
CDrinkH2O's Avatar
I recommend you reread it. The first post tells you what to do with pin 79.
Old Mar 13, 2021 | 02:08 PM
Rick2020's Avatar
5 Year Member
It says connect to a 12v source but where would I connect this wire to . Can anyone help please ?
1gcrazy
Jan 16, 2019 08:16 AM
Broke4speed
Aug 6, 2017 07:57 PM
maximusnz
Aug 9, 2009 02:13 PM
mandy1
Jan 9, 2008 08:55 PM
evo8dad
Nov 4, 2006 07:34 PM
