Idle afr
Old Apr 28, 2021 | 06:21 AM
wordword's Avatar
Idle afr
I'm in open loop targeting 14.7 in the fuel table, idling at 1000rpm, targeting 12deg. Timing jumps around a bit I guess as its hks 272 cams, but when logging target afr for some reason the ECU starts targeting 13.8 afr. I'll post a log when I get home
Old Apr 28, 2021 | 11:37 AM
Project_Broke's Avatar
Do you mean closed loop?
In open loop those numbers don't mean much in the table unless you have the fueling spot on, you may need to adjust it to match actual AFR. Unless you mean as soon as you start logging the actual AFR value changes?
Old Apr 29, 2021 | 07:21 AM
wordword's Avatar
so open loop does not look to the fuel table?
Old Apr 29, 2021 | 08:47 AM
RazorLab's Avatar
It's not a target AFR because the car has no idea what AFR is as it's not reading from a wideband.
There are many factors that go into that target.
Old Apr 29, 2021 | 05:53 PM
wordword's Avatar
ok so I'm on, SD map,. between, fuel table, maf scaling, maf comp and rpm ve, is there a preferred way to get afr where I want it?
Old May 4, 2021 | 08:36 AM
On SD you should be messing mostly with the SD RPM VE table and the fuel table to get to where you want. Assuming the SD VE Cal is close to what you want.
brusinn
Oct 1, 2013 04:41 PM
07EvoIX
11
Jun 6, 2012 03:29 PM
EVO8emUp
Dec 10, 2011 11:56 PM
PeteyTurbo
Oct 29, 2007 01:42 PM
