Help, Problem with Ceddymod in SD EVO 5 JDM
Old Jun 12, 2021 | 11:10 PM
GEVOXI's Avatar
Hello friends, I have a 22580006 EVO 5 GSR JDM currently installed with ceddymod patch using with maf, I saw in the forum how to make the speed density option work by interleaving the ecu pins using signals for the MAP sensor in that case I bought a MAP OMNI 3Bar I found in the forum threads how to calibrate them but I still haven't managed to start the car just using with maf.
My question is: they would have a tutorial on how to connect the MAP so give in the options of the Ceddymods SD and make it work using the calibrations obtained from the forum.
I would appreciate your help or I agree to send paypal if you help me.
Mods:
- Grimmspeed boost manual, HKS Intake, ID1000 injectors, run on E85 Fuel, 272 Cams, supertech heads kit, Wiseco Pistons, oem rods, 450lph walbro, Turbo EVO9, Exhaust 2.5 "..
Thanks ..
Captj
May 13, 2021 03:37 AM
wtf_is_a_evo
Jun 6, 2018 03:20 PM
eazlan
Dec 28, 2016 09:46 AM
gvr4v
Jul 19, 2016 09:00 AM
03lances
Feb 1, 2010 09:09 AM
