Final Edition Disable DTC p0247 p0243
Old Jul 22, 2021 | 12:13 PM
C G's Avatar
C G
Question Final Edition Disable DTC p0247 p0243
I have the FE ecu. 52680002 xml. I'm getting the dtc p0243 and p0247. I zeroed out every boost table, every solenoid table, passive and reactive.
I've looked on the forums and found information but none of the disable dtc xml posts include my ecu. I wouldn't want to put in the wrong definition with the wrong address.
I've attached my rom if that helps at all. You can look at it and see what I've done with it so far.
Any help is much appreciated!
I'd even be willing to find the pins that go to the solenoid and solder on a resistor or something to trick the ecu. Whatever I can do. I don't have the solenoids to install.
File Type: zip
Old Jul 22, 2021 | 03:48 PM
RazorLab's Avatar
Best bet is to get a solenoid and plug in the plugs
Old Aug 11, 2021 | 03:04 AM
sub7's Avatar
PM me, I can turn off P0243 and P0247. I need the .bin file, not .srf.
evovette
Oct 18, 2025 01:23 PM
gudmundur
Feb 21, 2016 02:50 PM
Frew
Mar 25, 2012 02:04 PM
MRGEVO
May 3, 2011 02:54 AM
Icem@n
Oct 21, 2010 01:33 PM
