Need XML Editing Help
Old Dec 31, 2023 | 08:46 AM
Cobrajetguy's Avatar
Trying to add some tables to TephraMOD-88590715-v7 XML but only some are showing up and could use some help.
I have successfully added this:
<table name="Minimum IPW #1 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="2af7a" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #2 SHLL2->NOP (0x4908 -> 0x0009)" category="Misc" address="2af7c" type="1D" scaling="Hex16"/>
<table name="Minimum IPW #3 SHLL->NOP (0x4900 -> 0x0009)" category="Misc" address="2af7e" type="1D" scaling="Hex16"/>
<scaling name="IPW16:SHLL0" units="ms" toexpr="x*8/1000" frexpr="x*1000/8" format="%.3f" min="0" max="65" inc="0.008" storagetype="uint16" endian="big"/>
<table name="Minimum IPW SHLL0" category="Misc" address="1102" type="1D" scaling="IPW16:SHLL0"/>
And this:
<scaling name="CoilDwellTime" units="ms" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.32" inc="0.064" storagetype="uint8" endian="big"/>
<scaling name="CoilDwellTimeUpperBoundPercent" units="% of Eng Revolution Time" toexpr="100*x/256" frexpr="256*x/100" format="%.1f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<scaling name="Percent256-8" units="%" toexpr="100*x/256" frexpr="256*x/100" format="%.2f" min="0" max="99.609375" inc="0.00390625" storagetype="uint8" endian="big"/>
<scaling name="RPMInverse-16" units="RPM" toexpr="7500000/x" frexpr="7500000/x" format="%.0f" min="0" max="10000" inc="60" storagetype="uint16" endian="big"/>
<table name="Ign Coil Base Dwell-Time" category="Misc" address="3cc6" type="2D" level="2" scaling="CoilDwellTime">
<table name="Battery" address="6e0c" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ign Coil Dwell-Time Reduction Start RPM" category="Misc" address="1346" type="1D" level="2" scaling="RPMInverse-16"/>
<table name="Ign Coil Dwell-Time RPM Reduction Factor" category="Misc" address="3cd6" type="2D" level="2" scaling="Percent256-8">
</table>
<table name="Ign Coil Dwell-Time Upper Bound" category="Misc" address="3ce6" type="2D" level="2" scaling="CoilDwellTimeUpperBoundPercent">
</table>
<table name="Ign Coil Dwell-Time Cranking" category="Misc" address="3cc6" type="1D" level="2" scaling="CoilDwellTime"/>
<table name="Ign Coil Dwell-Time Cranking Upper Bound" category="Misc" address="3ce6" type="1D" level="2" scaling="CoilDwellTimeUpperBoundPercent"/>
But I can't seem to get the injector linearization tables to show up:
<scaling name="InjLinearizationPWScale" units="PW Adder (ms)" toexpr="x*0.004" frexpr="x/0.004" format="%.3f" min="0" max="0.5" inc="0.004" storagetype="uint8" endian="big"/>
<table name="Injector Flow Linearization PW Adder" category="Misc" address="31db" type="2D" level="2" scaling="InjLinearizationPWScale"/>
<table name="Requested FPW (ms)" type="Static Y Axis" elements="66"/>
<data>0.016</data>
<data>0.048</data>
<data>0.080</data>
<data>0.112</data>
<data>0.144</data>
<data>0.176</data>
<data>0.208</data>
<data>0.240</data>
<data>0.272</data>
<data>0.304</data>
<data>0.336</data>
<data>0.368</data>
<data>0.400</data>
<data>0.432</data>
<data>0.464</data>
<data>0.496</data>
<data>0.528</data>
<data>0.560</data>
<data>0.592</data>
<data>0.624</data>
<data>0.656</data>
<data>0.688</data>
<data>0.720</data>
<data>0.752</data>
<data>0.784</data>
<data>0.816</data>
<data>0.848</data>
<data>0.880</data>
<data>0.912</data>
<data>0.944</data>
<data>0.976</data>
<data>1.008</data>
<data>1.040</data>
<data>1.072</data>
<data>1.104</data>
<data>1.136</data>
<data>1.168</data>
<data>1.200</data>
<data>1.232</data>
<data>1.264</data>
<data>1.296</data>
<data>1.328</data>
<data>1.360</data>
<data>1.392</data>
<data>1.424</data>
<data>1.456</data>
<data>1.488</data>
<data>1.520</data>
<data>1.552</data>
<data>1.584</data>
<data>1.616</data>
<data>1.648</data>
<data>1.680</data>
<data>1.712</data>
<data>1.744</data>
<data>1.776</data>
<data>1.808</data>
<data>1.840</data>
<data>1.872</data>
<data>1.904</data>
<data>1.936</data>
<data>1.968</data>
<data>2.000</data>
<data>2.032</data>
<data>2.064</data>
<data>2.096</data>
</table>
</table>
When I add the injector linearization to the xml I can no longer see any maps when opening the rom, it opens and has categories but nothing in them. Any advice would be greatly appreciated
Old Jan 1, 2024 | 05:45 PM
HyperDisorder's Avatar
Remove the two "/" at the end of the lines like in my screenshot (highlighted). They were the only differences that I could see
Old Jan 5, 2024 | 02:40 PM
almeaan's Avatar
I need help
Looking for a rom developer to make something custom for me.i am struggling for months now to edit my car. Willing to pay$$$.
Old Jan 6, 2024 | 09:44 PM
That worked, thank you so much!
vtw
Lancer Engine Management / Tuning Forums
Aug 12, 2018 11:20 AM
Ksay3
E85 / Ethanol
Sep 25, 2015 12:34 AM
ferrell1198
Jan 14, 2015 01:29 PM
liyellowevo8
Jun 2, 2010 06:50 AM
