help with tephra v7
Old Feb 6, 2010 | 04:36 PM
liyellowevo8's Avatar
help with tephra v7
I need help getting v7 to work with my ecuflash. I tried following the directions I dont know if its somthing Im missing. Any help appreciated.
Old Feb 6, 2010 | 04:53 PM
tephra's Avatar
whats the problem?
are you using ecuflash 1.42 (or a recent ver?)
did you copy the tephramod-94170015.xml into the evo directory? C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
i presume you are trying 94170715?
did you open the ROM file included in the V7 zip?
Old Feb 7, 2010 | 08:30 AM
First off thanks for answering me back.
Second I am using 1.42 I can easily download the newest version if I need.
I keep trying 96530706 cus I thought thats what Im supposed to use.
Old Feb 7, 2010 | 08:45 AM
I just tried 94170715 just to see if that would work and still nothing. I copy the xml file like you say into the evo directory. I dont understand what could be the problem?
Old Feb 7, 2010 | 08:58 AM
mt057's Avatar
I put the 94170015 xml directly into the rom metadata directry. I did not put it into the mitsubishi sub file just into the rom metadata file. I also had to get rid of my old rom.
Old Feb 7, 2010 | 09:15 AM
What do you mean get rid of your old rom?
Old Feb 7, 2010 | 02:23 PM
tephra's Avatar
so what happens when you open the included .bin file?
Old Feb 7, 2010 | 09:27 PM
It says windows cannot open this file.
Old Feb 7, 2010 | 09:31 PM
tephra's Avatar
are you using EcuFlash to open (ie NOT double clicking on the file itself)?
copy/paste the error image here (use alt-printscreen to copy it, mspaint + paste to save it, and imageshack.us to host it)
Old Feb 7, 2010 | 09:40 PM
Ok I just opened the 96530706 with ecuflash and everything is there that should be. Do I just use that and copy my roms fuel maps and everything over to it? Is there a way to make that come up everytime I open ecuflash?
Old Feb 9, 2010 | 05:51 PM
I just can't seem to figure this out.
Old Feb 9, 2010 | 05:53 PM
tephra's Avatar
When you start with the base rom file you need to copy your current tune into that ROM.
its a bit complicated, but there used to be a howto thread floating about...
Old Feb 9, 2010 | 10:43 PM
Ya cus I cant just flash that new one on my car. I always have to copy and paste on to the rom I pull from my car or a saved one from my car. I tried doing what you said but the new tables the load and rpm are higher than mine so I was just going to redo it but you probably know the deal, when flash it on and go to start my car I get no start.
Old Feb 14, 2010 | 11:32 AM
03lances's Avatar
I am having an issue as well, I am using ecuflash 1.42, I removed my old 94170015.xml file and saved it elsewhere, then put the the tephra 94170715.xml in the evo folder and opened the tephra rom and this is what I get
I am thinking I am missing something obvious but im still new at all this. Thanks in advance and sorry not trying to hyjack just figured I would post here instead of starting another thread.
Old Feb 14, 2010 | 11:37 AM
03lances's Avatar
Wait nvm think i got it i should not have removed the other xml huh? lol
