03 Lancer 5spd problems....Colby READ
ok talked with malibujack and got the cable working.....trying to get the ROM pulled from the ECU this is what i get....
[05:02:50.390] Version 1.28.716
[05:02:50.400] 8 memory models read.
[05:02:50.921] 71 ROM metadata models read.
[05:02:50.921] checksum module "subarudbw" loaded.
[05:02:50.921] flashing tool "wrx02" loaded.
[05:02:50.921] flashing tool "wrx04" loaded.
[05:02:50.921] flashing tool "sti04" loaded.
[05:02:50.921] flashing tool "sti05" loaded.
[05:02:50.921] flashing tool "mitsukernel" loaded.
[05:02:50.921] flashing tool "mitsukernelocp" loaded.
[05:02:50.921] flashing tool "mitsubootloader" loaded.
[05:04:04.096] sending init sequence 1 (0001)
[05:04:05.138] got 0x05 response
[05:04:05.148] sending init sequence 2
[05:04:05.158] got 0x1B response
[05:04:05.168] sending init sequence 3
[05:04:05.578] entering bootloader
[05:04:05.588] sending kernel size (3424)
[05:04:05.628] sending kernel load address (0xFFFF6000)
[05:04:05.678] uploading kernel
[05:04:06.239] verifying kernel checksum response
[05:04:06.249] kernel valid
[05:04:06.459] kernel get version
i have the car off with the prog running....then get ready to pull the rom....turn the car to the ON postion....then click OK....and i get ^^^^^ with an error pop-up saying check the log. any ideas?? and for ****s and giggles i tryed pulling the ROM with the car on and it killed it....so the cable seems to be working i guess.....ANY IDEAS???
ok im a retard....i was selecting Eclipse AT.....im dumb. well i dont see an option for any REG. Lacer so i chose 3rd Gen. guess that is what i want....my car fits those years......or so i pull the ROM off and then it asks how i want to "save it" do i just use the same parameters as it recommends or what? it says EVO7.....
need help.....when i pull the ROM off it then says:
Unknown ROM Image.
This wizzard will gernerate a basic ROM definition information needed to start working with this ROM image....
what do i choose? defined from scrach? copied from definition below? or inherited from definition below? below it says <evo7base>.....what do i do??
and when i click on anyone of those it "works".....i dont know what tu put of MXL definitions? and also when i clikc say High Octane Map i get this error
Current map description is invaild or incomplete. please edit map description to fix the problem and the map will be viewable again???
Unknown ROM Image.
