ECUFlash / Evoscan / Mitsulogger Questions
Old Jul 28, 2011 | 10:06 AM
  #991
evo_q8's Avatar
My rom id is 88840017 and recently when i used map tracer, it would give me a weird error sayin my xml was bad. i tried doing everything i could and it still wouldnt work. Deleted the xml and tried opening the file and as usual it comes up as unidentified.. i messed around and used an invalid one and now i cant return it back to the 88840017 id... lol
i should stop messing around with this thing ... lol
help!
Old Jul 31, 2011 | 04:40 PM
  #992
PlanoEvo's Avatar
my LoadMUT2Byte is maxing out at 379.6875 is the max or should I be using a different Load in evoscan?
Old Aug 2, 2011 | 04:53 AM
  #993
Peter10654's Avatar
Little Question:
What changes are necessary my AEM Wideband read correct values in Evoscan... At the moment I see external wideband 147 but need to see the logs with 14.7 !!
Need a correct scaling of the logs... Any helps ?
Thanks
Peter
Old Aug 4, 2011 | 07:29 PM
  #994
black_beauty's Avatar
If mitsulogger cant read codes, is there any current software that can? And can I log boost with mitsulogger? im sure i need a new map sensor at least. Thanks
Old Aug 5, 2011 | 05:18 PM
  #995
catman78's Avatar
ok I'm quite lost. 1st, I could not get ecuflash to read ROM.
So I saw on the EVOSCAN 2.7 menu bar an option to ReflashECU - read/write ecu- I selected correct car and clicked read
file was created FlashImage_20110508_1727.hex
Now how do I open this file to view tables?
thanks
Old Aug 5, 2011 | 11:37 PM
  #996
And's Avatar
And
you should open it in ecuflash but im guessing that you havenmt got the correct xml definition for it, if you upload it then which file you need
Old Aug 6, 2011 | 01:51 AM
  #997
catman78's Avatar
does ecuflash check this directory for a match?
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Is this where I need to place correct xml file for my car?
I have an USDM 05 Evo VIII
Old Aug 6, 2011 | 01:52 AM
  #998
catman78's Avatar
I've checked here:
http://www.evoscan.com/roms/mitsubishi/
could not find EVO8 only 7-9
Old Aug 6, 2011 | 03:49 AM
  #999
dparrish's Avatar
8 is between 7 and 9.
Do you know which ROM id you have? What does ECUflash tell you when you open it?
Old Aug 6, 2011 | 04:57 AM
  #1000
catman78's Avatar
I have an old laptop running XP. The problem I'm having is getting the list of cars to select from.
I've moved all the read_xxxx.xml files to the ROM directory and still cannot get list to populate.
Installed/reinstalled latest version several times, no luck.
Old Aug 6, 2011 | 05:05 AM
  #1001
dparrish's Avatar
Oh I see. You've already read the ROM file using EvoScan, so you just need to open that file in EcuFlash (Ctrl-O to open it). EcuFlash and EvoScan both use separate XML files. You can use EcuFlash to read the ROM as well, but if you've already read it then you don't need to.
When you open the .hex file in EcuFlash it will either give you a big list of tables you can edit, or it will say it's an unknown ROM image. If it says that, follow the prompts to create a new definition and during that process it will show you the ROM id (or Internal ID, I can't remember which it says). That will be a 9 digit number, probably starting with 9. Grab the XML file for that rom id and put in ecuflash's rommetadata directory, re-open ecuflash and open the rom file again.
Old Aug 6, 2011 | 10:56 AM
  #1002
catman78's Avatar
thanks for all your help dparrish.
Just picked up a newer laptop from one of my buddies. Gonna give that a shot.
Thanks again.
Old Aug 6, 2011 | 12:23 PM
  #1003
catman78's Avatar
New laptop, tried ecuflash. list of cars came up selected mine and began to read.
then I got error
0001
0003
FFFF
no response to any known code
Then I downloaded ROM using EVOScan. Tried to open ROM using EcuFlash and got
Unknown ROM Image.
abort
or
use wizard to create a new definition(NOT RECCOMEDNED.......)
Old Aug 6, 2011 | 03:19 PM
  #1004
dparrish's Avatar
Click "Use Wizard to create a new definition" and follow the prompts until you get the ROM ID.
Old Aug 6, 2011 | 04:12 PM
  #1005
catman78's Avatar
Gettin there man. AAHHHH.
So I downloaded ECU Unlocker and ran prior to starting ECUFlash.
Rom seemed like it was read, however the file looks small. When I expanded the file in ECUFlash I didn't get much info. Here's a shot.
