Air Temp Compensation table
Old Feb 6, 2009 | 09:38 AM
  #241
D-VO's Avatar
Originally Posted by 03whitegsr
It definitely throws a HUGE variable in this. Especially considering most of us find our AFRs to be fairly stable with air temps.
Considering the water/meth has ZERO compensation for air density. Even if the water/meth delivery is rock solid, it's going to cause HUGE changes in AFR with temperature changes.
I would like to be clear on what you guys are talking about. I'm using 93 octane only, and I was having an issue with my AFR stability in different weather conditions before MRFred introduced the correct Airflow/Hz correction table. Are you saying that if I have these changes in my hot and cold temperature AFR's that I'm using methanol? Or, is this situation only concerning the air density vs air temp table?
I'd also like to share a tidbit concerning fuel by brand. I've noticed that I have to enrich my fuel maps when using Hess gasoline as opposed to when I use Shell or Mobile in which I have to enlean my fuel map. Has anyone else tested this?
Old Feb 6, 2009 | 09:58 AM
  #242
03whitegsr's Avatar
No, I'm questioning if his AFR changes are due to his water/meth injection.
Your's may be a different issue all together or there may be something else causing the AFR changes that is showing up on some cars but not others.
On 94170015, I get very little change (less then ~0.2) in AFR with IAT ranging from 0F-80F. I can't say above 80F if the AFR remains stable or not.
Old Feb 6, 2009 | 11:20 AM
  #243
honki24's Avatar
Perhaps you're right. Perhaps it has more to do with water/meth. Yes I've been using it the whole time. No there's no way to compensate. It's simply an on/off solenoiod @ 12psi.
-Yes I have leanspool disabled-
Suppose I could test without injection... but that's even more work. lol, I'm lucky I'm allowed to tune and get out to the race track as it is. Plus it takes about a quarter tank every time I take the car to work to tune. Good point though. Suppose I don't know very well how water is going to affect AFR. At any rate, this table seems to help but I've still got the issue where my initial pull AFRs are about .8ish leaner than those that I see after I do many hard runs.
Old Feb 6, 2009 | 12:03 PM
  #244
03whitegsr's Avatar
Keep an eye on your intake and coolant temps under those conditions. Usually, the IAT are considerably cooler the first couple pulls because the engine bay has not become heat soaked. If the engine is not completely up to operating temp, you could be getting some funky AFR corrections based on coolant temp as well.
If you have a good sealed off intake system that sources air from outside the engine bay, the IAT stuff is much less of an issue (basically non-existent).
If the issues are being caused by the water/meth, which I suspect they are, that doesn't mean it can't be tuned for. You just need to have a proper understand of what the actual issue is before you can correctly tune for it.
Old Feb 6, 2009 | 09:23 PM
  #245
D-VO's Avatar
OK I see. What do you think about the bit on gasoline brands? What brand of gasoline are you using and do you generally use the same brand of gasoline all the time?
EDIT:
Tested AFR's using Shell, Mobile, Sonoco, and Hess; all AFR's had very minor changes(.2)
Old Feb 11, 2009 | 07:46 AM
  #246
honki24's Avatar
I need to get my WB issues sorted out before I look into this much further. It seems as I beat on the car very hard the AFR gets richer and richer until it says 10:1 under load and 20:1 at no load. I think I've overheated the sensor and I'm not sure I can trust its output right now. I've ordered a new sensor and a copper sheet to make a heat sink.
Old Feb 24, 2009 | 05:41 AM
  #247
honki24's Avatar
Okay, it was definitely my WB sensor.
Old Mar 13, 2009 | 10:14 AM
  #248
D-VO's Avatar
What kind of wideband were you using?
I noticed a difference when using AEM as opposed to the Innovate. I'm not quite sure of which sensor to trust as both sensors are about the same age.
Old Jan 9, 2010 | 08:51 AM
  #249
kruthles's Avatar
Is the XML for the "Fuel Trim vs Air Temp" table available for 88590015? I am currently stuck using the "Airflow/Hz Baro and Air Temp Compensation" table in Ecuflash because I am unable to locate the correct XML.
Table in question is below:
Old Mar 11, 2010 | 03:40 PM
  #250
Jorge T's Avatar
I've seemed to cure my AFR temp change for e85 w/fic1050.
yesterday it was almost 80f, last month it dipped to 32f giving me opportunity to play with it.
The cooler it got the leaner it was
This was stock
Attached Thumbnails Air Temp Compensation table-custom-iat-fuel-comp.png   Air Temp Compensation table-stock-iat-fuel-comp.png
Old Mar 11, 2010 | 06:46 PM
  #251
kruthles's Avatar
I am also on e85 with the FIC1050s and have had the same exact issue. Thanks for posting your tables!
Old Mar 12, 2010 | 01:34 AM
  #252
EvolutinIX's Avatar
I also would like to know which wideband went south on ya?
Old Mar 23, 2010 | 12:31 AM
  #253
merlin.oz's Avatar
this thread is a damm good read, but, the snipit of info I'm after has not been covered.
Specifically, over what barometric pressure range will the system compensate for.
The reason for the research is, of course, running Pikes Peak in July.
The initial tuning will be done in Australia, then whatever else on the mountain, starting at 9000 feet and on to 14000 feet. Sheesh! Will it work or not!
Old Jun 29, 2010 | 04:34 PM
  #254
PlanoEvo's Avatar
This was stock
Where is this table I am using tephraV5 and I cant see to locate it?
Old Jul 14, 2010 | 11:36 AM
  #255
PlanoEvo's Avatar
Bump anyone?
