ECU Swap & Immobiliser Code Issues
#31
Registered User
just tried it and this comes up:
and i can only touch certain things in my table.
Parse error at line 256, columns 171
unknown table data storage endian type [CHANGEME]
#33
Registered User
try the ROM I suggested... I had the same problem with the one Tephra suggested which is why I didn't ask you to try it
#34
1 Post
ok, I got confused about something you said earlier I guess...use the xml file that comes with the ROM first to make sure it works rather than trying to copy bits from it and put it into your existing .xml
#35
Registered User
#41
Registered User
did you change "CHANGEME"?
do you have some sort of instant messenger like MSN (you can PM me it) it would make this a lot easier!
#44
Registered User
i am not spanish, just doing this for the first time
anyhoo i got it to work.... well u guys did!
Thanks guys!
now to tuning!
PS no rear O2 sensor so i should be fine!
Thanks guys!
now to tuning!
