Map rescaling question
Since I'm running higher boost I've already rescaled my fuel and ignition maps to read up to 340 load...my question is, do I need to also rescale my mivec map to match the others since currently its scaled to 300?
In practice, it's best to keep your maps scaled to the values they will be hitting.
Once it runs off the end of the map, it will use the values from the last column, so if you don't care that your intake cam advance is the same @ 300 load as it is at 340 load, then you don't have to change it.
