airflow 2-byte mod for 96260009
Could someone please share this info with me?
I have been trying for a while now to locate the right data for the MUT tables to modify it so I can log the 2byte airflow in my 2.61 evoscan and the 96260009 rom withou success.
Please help.
Cheers.
P.
Please help.
Cheers.
P.
https://www.evolutionm.net/forums/ec...ml#post7056799
Look at posts #222, #223 and #224. Tephra said to use 8984 and 8985 for 2-byte Load and nitz confirmed that they worked. The values are the same for my rom, 96420008. See if the other values work for 96260009.
96420008
2byte load
MUT 00 = 8984
MUT 01 = 8985
2byte RPM
MUT 02 = 8962
MUT 03 = 8963
2byte AirFlow
MUT 04 = 89E2
MUT 05 = 89E3
MUT 3D TABLE ADDRESS = 39FA0
96420008
2byte load
MUT 00 = 8984
MUT 01 = 8985
2byte RPM
MUT 02 = 8962
MUT 03 = 8963
2byte AirFlow
MUT 04 = 89E2
MUT 05 = 89E3
Confirmed 2-byte Airflow is 89E2 89E3 for 9626 series roms.
Can I make a suggestion here, leave MUT location 00 and 01 as stock values, so a scan tool can read airflow in gm/sec.
I mod MUT locations 02 and 03 for 2-byte spark load (baro compensated) and set MUT 04 and 05 for 2-byte Airflow (as we normally do here). EvoScan xml will have to be tweaked for this though.
Nuked
Jun 2, 2008 06:32 PM
