Log boost with Defi Boost sensor
Old Jun 7, 2009 | 01:00 PM
mlocatel's Avatar
Hello
I've a question for the experts.
I have a Defi Boost sensor mounted in my car. The sensor itself has 3 cables (black,white and red).
I suppose that black is ground, red is current and white is the signal.
Can anyone confirm me that? Is the sensor connected to 12V, or just 5V?
I would like to wire the sensor to the ECU to be able to log boost.
Thanks
mlocatel
Old Jun 7, 2009 | 02:21 PM
Toxin's Avatar
Sorry unable to reply to your question but if you haven't searched around much, people usually use the JDM Map 3bar sensor (now basically the stock evo X map sensor) to log boost.
Hope it helps if you're unlucky with the Defi.
Old Jun 7, 2009 | 02:33 PM
xRoguex's Avatar
+1 for jdm over gauge input.
Old Jun 7, 2009 | 09:57 PM
japanevo's Avatar
sorry the JDM map sensor seems to be the popular choice on this forum. however to answer your question it should be black = ground, red = 5v, and white = signal. from what i have read there should only be a slight difference in reading. i am surprised that the GM sensor isn't used more considering that it is half the cost. guess it is all about ease of install .
Old Jun 8, 2009 | 01:15 AM
mlocatel's Avatar
I would basically also use the GM, nonetheless I had the Defi from another project, so it could be worth using it and not letting it get dust on the shelf
Moreover if I want to use the GM, I have to drill an hole in the manifold, which I don't like too much.
mlocatel
Old Jun 8, 2009 | 03:20 AM
tephra's Avatar
how many bar is the sensor (what does the gauge go upto??)
if its 3bar do this:
hook up the power/ground like normal then use a DMM to measure the signal (just at atmo pressure)
if its about 1.5v then its 5v... if its 4-5v then its as 12v...
I suspect it will be 5v... in which case you can just hook up the signal wire to the ECU and it will work ok...
Old Jun 8, 2009 | 04:44 AM
mlocatel's Avatar
Hello Dave
it is actually a 2bar sensor. I'm not sure that this will be enough, but I do not have extreme mods (no FP, no E85)
I'll try like you suggested
Thanks
mlocatel
Old Jun 8, 2009 | 04:54 AM
tephra's Avatar
2bar on the display?
so 3bar atmo
let me know how u go
Old Jun 8, 2009 | 05:24 AM
mlocatel's Avatar
Yes
next weekend I'll wire it into the ECU
mlocatel
Old Jun 13, 2009 | 06:21 AM
mlocatel's Avatar
Hallo Dave
I installed the sensor with the 5V as source
it seems to be working. At idle is giving me 0.7 bar. I'm using the JDM MAP scaling as available in Evoscan-
Thnks for the help
mlocatel
Old Jun 13, 2009 | 06:25 AM
tephra's Avatar
So you will need to work out the scaling
So just log the RAW value in EvoScan (ie remove the formula and leave 'x') (rpm=0 of course)
Then report back and ill try and work it out for u
Old Jun 13, 2009 | 06:48 AM
mlocatel's Avatar
Hello Dave
I sent you an E-mail with the logs
mlocatel
Old Jun 13, 2009 | 07:18 AM
vmrevo9's Avatar
Veteran: Air Force
interesting. 2bar is about 29psi right?
i would like to learn more about this!
Old Jun 13, 2009 | 08:23 AM
mlocatel's Avatar
Yes
btu anyway tephra was right: the sensor is good for 0-3bar (2 bar boost)
As soon as either myself or tephra have the right scaling we'll put it there
Old Jun 13, 2009 | 09:54 AM
vmrevo9's Avatar
Veteran: Air Force
what did u use as a 5v source?
