Log boost with Defi Boost sensor
Old Jun 14, 2009 | 12:57 AM
mlocatel's Avatar
Pin 42
Old Jun 14, 2009 | 07:08 AM
Toxin's Avatar
Tephra for the win yet again
Old Jun 14, 2009 | 07:26 AM
thisxguy's Avatar
interesting
Old Jul 5, 2009 | 12:55 AM
claudiumxg's Avatar
what formula did you use in evoscan?
Old Aug 7, 2009 | 07:02 AM
simple_lancer's Avatar
The formula in Evoscan for the Defi Map sensor is (x-96)*0.21875 to read in PSI.
If you're not reading 0 with the engine off, you will have to change the 96.
Make the formula for logging boost just x. Log the value with the engine off. This will give you the correct value if 96 doesn't work where you are located.
I have a Defi Racer Series 52mm Boost gauge, I just tapped the signal and connected it to the ECU. I have a JDM 8MR using a 3 plug ECU, so I used pin 92 on the ECU.
Now I can log boost and run the boost gauge with the one MAP sensor
Old Aug 8, 2009 | 12:29 PM
KleenWhiteMR's Avatar
does anyone know the scaling for the apexi avcr sensor? i have one laying around and would like to use it to log boost
Old Aug 17, 2009 | 12:50 AM
SeanV's Avatar
This may help..
https://www.evolutionm.net/forums/ec...ml#post5648706
Old Aug 17, 2009 | 02:20 AM
SeanV's Avatar
I have a HKS RS DB boost gauge and it seems to have the same specs/output voltage etc as the Defi gauge/sensor.
I would like to use the above formula to log the boost but in need it to read in Bar, Please advise what changes I have to do to the formula to log in "Bar".
Thx
Old Aug 17, 2009 | 02:29 AM
mlocatel's Avatar
Thx
Simply divide the result by 14.5
Old Aug 17, 2009 | 02:48 AM
SeanV's Avatar
Wow that simple
So the formula will then be..
(x-96)*0.21875/14.5 (is this exactly how I would enter it into Evoscan?)
Thx
Old Aug 17, 2009 | 11:37 AM
mlocatel's Avatar
yes
Old Aug 19, 2009 | 06:20 AM
SeanV's Avatar
Wow that simple
Thx
Please help.....
Ok so I have my signal from the HKS boost sensor (5Volt with a 2bar boost gauge) wired into the Ecu on pin 73.
I first log the raw value with the rpm at 0, and I find it shows a value of 57.
I then change the above formula to
(x-57)*0.21875/14.4493.
I do a log with rpm = 0, and it shows me 0 bar on the dot.
I start the car and at idle I am seeing about -.35 to -.4 bar. hich is about right when compared to my gauge.
I then do a 3rd gear log but my logged values are too low.
My gauge shows a spike to 1,6 bar and settles to 1.5 bar before dropping down to 1,45 bar at redline.
Below is what I logged in "Bar" using the formula above...
Code:
TPS	RPM	JDMMAP
100	2093.75	0.060556567
100	2125	0.045417425
100	2125	0.075695708
100	2156.25	0.075695708
100	2156.25	0.09083485
100	2187.5	0.105973992
100	2218.75	0.121113134
100	2250	0.121113134
100	2281.25	0.151391417
100	2312.5	0.151391417
100	2343.75	0.166530559
100	2375	0.1816697
100	2375	0.1816697
100	2406.25	0.196808842
100	2437.5	0.196808842
100	2468.75	0.211947984
100	2468.75	0.227087125
100	2500	0.242226267
100	2531.25	0.242226267
100	2562.5	0.257365409
100	2593.75	0.27250455
100	2625	0.287643692
100	2656.25	0.302782834
100	2687.5	0.317921975
100	2687.5	0.348200259
100	2718.75	0.363339401
100	2750	0.393617684
100	2812.5	0.408756826
100	2812.5	0.439035109
100	2843.75	0.469313392
100	2875	0.499591676
100	2906.25	0.545009101
100	2937.5	0.605565668
100	3000	0.666122234
100	3031.25	0.711539659
100	3062.5	0.756957084
100	3093.75	0.817513651
100	3125	0.878070218
100	3187.5	0.953765926
100	3250	1.059739918
100	3281.25	1.105157343
100	3343.75	1.180853052
100	3406.25	1.211131335
100	3437.5	1.241409618
100	3531.25	1.211131335
100	3593.75	1.180853052
100	3656.25	1.16571391
100	3781.25	1.150574768
100	3843.75	1.150574768
100	3937.5	1.120296485
100	4000	1.120296485
100	4062.5	1.135435627
100	4125	1.120296485
100	4187.5	1.120296485
100	4250	1.135435627
100	4312.5	1.16571391
100	4343.75	1.135435627
100	4437.5	1.16571391
100	4500	1.150574768
100	4562.5	1.135435627
100	4593.75	1.135435627
100	4687.5	1.150574768
100	4718.75	1.150574768
100	4781.25	1.16571391
100	4843.75	1.16571391
100	4906.25	1.16571391
100	4968.75	1.135435627
100	5031.25	1.150574768
100	5062.5	1.135435627
100	5156.25	1.135435627
100	5187.5	1.135435627
100	5312.5	1.135435627
100	5343.75	1.135435627
100	5406.25	1.120296485
100	5437.5	1.105157343
100	5531.25	1.090018202
100	5562.5	1.120296485
100	5625	1.105157343
100	5687.5	1.105157343
100	5750	1.135435627
100	5812.5	1.16571391
100	5843.75	1.150574768
100	5937.5	1.135435627
100	6000	1.120296485
100	6031.25	1.135435627
100	6125	1.135435627
100	6187.5	1.105157343
100	6250	1.105157343
100	6343.75	1.07487906
100	6375	1.07487906
100	6437.5	1.07487906
100	6468.75	1.044600777
100	6531.25	1.044600777
100	6593.75	1.029461635
100	6656.25	1.044600777
100	6718.75	1.014322493
100	6750	0.999183351
100	6812.5	0.999183351
100	6843.75	0.999183351
100	6906.25	0.98404421
100	6968.75	0.999183351
100	7000	0.968905068
100	7093.75	0.98404421
100	7156.25	0.953765926
And another doing exactly the same but logging the raw data..
Code:
TPS	RPM	JDMMAP
100	2125	58
100	2093.75	59
100	2156.25	60
100	2156.25	59
100	2125	60
100	2187.5	61
100	2187.5	61
100	2187.5	62
100	2250	63
100	2250	62
100	2250	62
100	2281.25	63
100	2281.25	64
100	2281.25	64
100	2312.5	64
100	2343.75	64
100	2343.75	64
100	2375	66
100	2406.25	65
100	2406.25	67
100	2437.5	68
100	2437.5	68
100	2468.75	68
100	2500	68
100	2500	69
100	2531.25	69
100	2562.5	70
100	2562.5	71
100	2593.75	72
100	2625	73
100	2625	73
100	2656.25	74
100	2687.5	74
100	2687.5	75
100	2718.75	76
100	2750	77
100	2750	78
100	2781.25	79
100	2812.5	79
100	2812.5	81
100	2843.75	82
100	2875	83
100	2875	84
100	2906.25	87
100	2937.5	88
100	2968.75	91
100	3000	94
100	3031.25	96
100	3062.5	99
100	3093.75	101
100	3125	103
100	3156.25	108
100	3218.75	112
100	3250	116
100	3312.5	120
100	3343.75	125
100	3375	131
100	3437.5	134
100	3500	135
100	3531.25	134
100	3593.75	136
100	3656.25	133
100	3718.75	135
100	3781.25	133
100	3812.5	133
100	3906.25	134
100	3906.25	133
100	4000	132
100	4062.5	133
100	4093.75	132
100	4156.25	132
100	4187.5	132
100	4218.75	134
100	4281.25	133
100	4343.75	135
100	4375	132
100	4437.5	131
100	4500	133
100	4562.5	131
100	4593.75	133
100	4656.25	134
100	4687.5	133
100	4781.25	132
100	4812.5	131
100	4875	132
100	4937.5	132
100	4968.75	132
100	5031.25	132
100	5093.75	132
100	5187.5	132
100	5218.75	132
100	5250	130
100	5312.5	131
100	5343.75	131
100	5406.25	131
100	5468.75	129
100	5531.25	131
100	5562.5	131
100	5625	130
100	5687.5	131
100	5718.75	133
100	5781.25	131
100	5843.75	131
100	5875	132
100	5937.5	132
100	6000	133
100	6031.25	132
100	6093.75	132
100	6125	130
100	6187.5	129
100	6218.75	130
100	6250	128
100	6281.25	129
100	6343.75	127
100	6375	129
100	6406.25	126
100	6437.5	126
100	6468.75	125
100	6500	127
100	6562.5	126
100	6593.75	124
100	6625	124
100	6687.5	123
100	6687.5	123
100	6750	122
100	6781.25	123
100	6812.5	121
100	6843.75	123
100	6875	122
100	6906.25	121
100	6937.5	121
100	7000	122
100	7031.25	119
100	7062.5	120
100	7093.75	121
100	7125	119
Not sure if this has any bearing...
I am at 5600 feet above sea level and my Baro on the car shows 0,84 Bar, is there an offset of some sort I need to add in the formula to compensate?
Thx..
Old Aug 19, 2009 | 07:36 AM
mlocatel's Avatar
Yes
the formula is for ca. 1bar, to compensate for your value you have to add the difference, so
value_new = value_original_formula + (1-0.84).
Anyway this formula yields for a Defi sensor. I'm not sure that the scaling is the same for the HKS.
The best is if you log the raw signal and you compare it with the reading of the gauge. Try 2 or 3 points where to pressure is quite contant (e.g. full throttle in 6th gear @ 2500rpm + idle)
LuckyManiac
Jun 26, 2017 03:45 PM
iLLevo_
16
Feb 19, 2017 09:30 AM
Chebosto
Oct 4, 2011 11:14 AM
tboboy
Aug 7, 2010 03:39 PM
evo4l
Mar 19, 2009 06:00 PM
