97470001 to 96530706-v7t6 Problem ...
Old Jul 26, 2009 | 07:57 AM
LeXcite's Avatar
Hi 2 all. Trying to convert 97470001 to TephraModV7T6, and can't get success.
Till i newbie to EcuFlash want to ask your help ...
My stock 97470001 has tuned. Tried to transfer maps to new Rom, but only some of them seen in V7T6.xml ... So, i transferred only basic maps : Hi\Lo Fuel\Ignition maps, Idle, and Immo tables...
After that it feels like I am hitting a brick wall when transitioning from vacuum to boost with this rom, at any RPM, and AFR goes to 10-11 ...
In Untouched AltMap, Boost is growin normally ... but knocks ...
Tried to increase Boost Limit table, but it already maximized ... What to do next? Im confused ...
Please help ...
1. My Stock Rom.
2. xml for my stock Rom.
3. TephraMOD V7T6 with my maps ....
Old Jul 26, 2009 | 08:02 AM
l2r99gst's Avatar
Your ignition maps are screwed up.
What do you have for the defs for the hi and low octane ignition map for 96530006?
Old Jul 26, 2009 | 09:50 AM
LeXcite's Avatar
<!-- *** TIMING *** -->
<table name="High Octane Ignition Map 1" address="39d5">
<table name="Engine Load" address="6910"/>
<table name="RPM" address="68de"/>
</table>
<table name="Low Octane Ignition Map 1" address="3b5d">
</table>
Attached Thumbnails 97470001 to 96530706-v7t6 Problem ...-high-octane.png   97470001 to 96530706-v7t6 Problem ...-low-octane.png
Old Jul 26, 2009 | 10:21 AM
l2r99gst's Avatar
Those defs are correct. Make sure you don't have different addresses in your Tephramod 96530706 XML.
When I open your maps, they are off by a column or something, so once you hit the boost range, timing drops to -10.
Old Jul 26, 2009 | 01:44 PM
LeXcite's Avatar
Exactly those address ... How is my stock map?
V7T6 xml from Phenem ....
Old Jul 26, 2009 | 01:56 PM
LeXcite's Avatar
Forgot to say that Y-axis i edited to 19 elements in timing maps def.... so last one 11.000 rpm is gone till i don't need one ... may be this is problem ?
Old Jul 26, 2009 | 03:19 PM
nothere's Avatar
are you using ecuflash 1.42?
Old Jul 26, 2009 | 04:16 PM
LeXcite's Avatar
EcuFlash
Version 1.42.2595
Old Jul 26, 2009 | 04:34 PM
nothere's Avatar
removed extraneous evo 7base, and 006?
reason I ask, you say you are missing some maps?
Old Jul 26, 2009 | 06:34 PM
l2r99gst's Avatar
What did you do? That is probably the problem.
When I look at your map it looks like it is off by a column or something. Everything is shifted and this causes your timing to be really messed up...like -10 in boost areas.
I'm guessing whatever you did is the problem.
Old Jul 27, 2009 | 10:53 AM
Appauldd's Avatar
Same proble here.....My tables are all stock. What gives????
Old Jul 27, 2009 | 11:38 AM
l2r99gst's Avatar
How many RPM elements do you have in your timing map? There has to be 20. That is what the problem was for the OP here. It sounds like he deleted a column or something, which shifted all of his data and screwed up the whole map.
Old Jul 27, 2009 | 01:27 PM
LeXcite's Avatar
Exactly!
20 columns and it works ... Big Thanks ...
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
scheides
Mar 6, 2014 08:09 AM
Anubis18
Sep 20, 2013 02:39 PM
03whitegsr
Oct 17, 2009 10:20 PM
