PATCH: Clutchless starting without disconnecting the clutch position switch?
Since Tephra uses the clutch switch to trigger the NLTS, the switch must be accessible to the ECU. Does anyone have a patch/mod for the Tephra 5.1 (or v7) to allow the car to be started without pushing in the clutch, but while leaving the clutch switch connected?
Ideally for 96530006 or 96530706, and as a bit flag that could enable/disable it.
It might be a periphery bit, but searching hasn't found it for me, yet.
Thanks!
Thanks!
Ah, I didnt know there are two clutch switches. I guess let me rephrase, and say is it possible to mod the ROM so that the car can be started without the clutch depressed? I don't care if NLTS is functional or not, I don't use it. I'd just like to have the car startable without the clutch depressed, without having to physically unhook the wire.
Thanks for the replies so far.
I recently got IDA pro, and thought it might be a fun mod to learn disassembly with if it was possible, and nobody had done it yet. He and I both run the 96530006 ROM on Evo 8s, so it would be easy to test.
Thanks for the info Dave!
franzcars
Jul 26, 2023 09:27 AM
99, clutch, clutchless, disconnect, ecu, evo, flash, gst, hookup, mitsubishi, mod, nlts, position, start, switch
