Dialing in injectors w/out rear o2?
And about .121 seconds of searching would have told you that certain ways of disabling the rear o2 also causes fuel trims to stop working. I can't remember which but there's ways to disable it without losing your trims. Or you can enable it, let the cel come in, dial in your injectors, then disable it again.
I don't think there is such a thing as rear o2 "trims", but certain ways of disabling the rear o2 disables fuel trims, which do come from the front o2 sensor.
https://www.evolutionm.net/forums/ec...rim-issue.html
This is a thread that I started for the same issue. It's been discussed in several other threads also.
vicbdn
May 10, 2006 08:41 PM
masterevo
Mar 30, 2005 01:30 PM
