How are u guys launching with V7 launch map
Old Jun 8, 2010, 12:20 PM
ant_turbo's Avatar
How are u guys launching with V7 launch map...
Do u just mash the throttle?? or hold it till launch map activates then mash the throttle,,,, THANKS
Old Jun 8, 2010, 03:18 PM
ant_turbo's Avatar
Bump!!
Old Jun 8, 2010, 04:56 PM
chmodlf's Avatar
Push pedal slowly until rpm reaches limit and then slip clutch. Tempo of the clutch pedal is the key to clutch drivetrain health.
Old Jun 8, 2010, 05:50 PM
ant_turbo's Avatar
I know how to launch!
Just asking how are people are launching with the new launch maps in Tehpra V7
Old Jun 8, 2010, 05:52 PM
Spec-Ops1's Avatar
we are playing around with it....
we have it building about 18 psi from the gates, which we want a little lower. Then we are running to an issue with a bit too much fuel during launch causing us to bog. Haven't quite dialed it in yet, but we are pretty darn close.
Old Jun 8, 2010, 05:57 PM
wizzo 8's Avatar
18psi holy cr@p!
Old Jun 8, 2010, 08:52 PM
ant_turbo's Avatar
ya someone needs to get this dialed in for diff boost settings,,,
Old Jun 8, 2010, 09:10 PM
ant_turbo's Avatar
Whats ur TPS setting..
Old Jun 8, 2010, 09:35 PM
hediki12's Avatar
once my clutch goes back in ima mess around with it i built 15psi on my 16g im aiming to make the transition on2 the regular map as smooooooth as possible. i think that will b the key for non boggy-ness
Old Jun 9, 2010, 02:17 AM
Spec-Ops1's Avatar
That is one of the things we are playing with... using TPS to achieve a lower boost setting as well as reducing the amount of fuel during launch.
The transition is the most difficult part, but what we are trying to dial in is the shift.... I'm trying to make it so we are on the launch map thru 1st gear and when the shift to 2nd comes up its in the transition phase.
Old Jun 9, 2010, 12:25 PM
elhalisf's Avatar
I was using the V7 launch map on the red and was building up 16psi at 5750 rpm. I had awesome launches!
now, i changed to the SD V7 map, and every time i let the clutch out to launch, the engine will just die. it will take a few seconds to start back up as if the engine is flooded.
Any idea's on what could be wrong?
Old Jun 9, 2010, 12:33 PM
Chris Moore's Avatar
You mean it will bog and die? Or just instantly die?
Old Jun 9, 2010, 12:38 PM
elhalisf's Avatar
It will just die!
the map is the same i had before converting to SD, and i had no issues then.
Old Jun 9, 2010, 01:10 PM
Spec-Ops1's Avatar
This is what we are experiencing. The car that we are using for the test car is our owners SD VIII. Exact same problem... we have gotten it better... it wont die, but does seem flooded. We have almost got it worked out though. Need a handful more track passes to finalize it.
Old Jun 10, 2010, 12:09 AM
ant_turbo's Avatar
Bump,,, for more users...........
Quick Reply: How are u guys launching with V7 launch map
