Evo ix Maf comp vs coolant temp?
Old Oct 5, 2010 | 09:16 PM
heybudddy's Avatar
Is there a table for this for 88590015 rom? Helping a friend with a cold start lean issue. Car fires up and idles good. If you try to drive off right away, car will go lean and want to die out as you touch throttle. Minute later it will drive off. Looking for a table like a maf comp vs coolant to force the car to run a bit rich on in the low coolant temp areas.
I have seen it for the Evo 8 but not for evo IX.
Thanks
Old Nov 5, 2010 | 10:00 PM
F0RSAKEN's Avatar
Bump, same question
Old Nov 6, 2010 | 12:57 AM
drifterific's Avatar
I know on the 965 variant of tephra these settings are under the Global Fuel Settings menu towards the bottom. Im not sure if they are in the same place on the evo 9 variant. I will download a rom and take a look here in a bit.
EDIT--------------------
So I went and pulled 88590715 to see if it had the maf comp vs coolant temp and realized that there were no settings like that for the evo 9 like there are for the evo 8. I did see "Injector Cranking Enrichment IPW Adder (Main)" that might be able to be used for making the car run a little bit rich on start up. Heybuddy what is the car leaning out to when you try to drive it on cold start?
Old Nov 6, 2010 | 08:16 AM
Raptord's Avatar
I'd love something like this as well...
Old Nov 7, 2010 | 03:41 PM
F0RSAKEN's Avatar
Bump... mrfred, Appauldd, tephra.. anyone?
Old Nov 7, 2010 | 04:18 PM
l2r99gst's Avatar
All of these tables are in mrfred's advanced fuel control thread. 8859 is the ROM that he uses to find all of these tables.
Old Nov 7, 2010 | 10:01 PM
F0RSAKEN's Avatar
You sir, are correct, and I completely missed that!
For reference, title of the code you need is A) Base fuel pulse....
Raceghost
Aug 10, 2018 10:39 PM
GeoMitsu
Oct 13, 2016 02:00 AM
Dynotech Tuning
Sep 20, 2016 01:30 PM
PPM
Apr 2, 2015 09:35 AM
VGergo
Dec 9, 2010 04:24 AM
