2byte load/Mitsulogger
Add these lines to your requestID.xml..
Code:
<Request LogReference="requestID00" RequestID="00" Eval="x" Unit="INT" Logged="y" Response="2"/> <Request LogReference="requestID01" RequestID="01" Eval="x" Unit="INT" Logged="y" Response="2"/> <Request LogReference="2ByteLoad" RequestID="FF" Eval="((256*requestID00)+requestID01)*10/32" Unit="2byteLoad" Logged="y" Response="2"/>
Just afraid to disable the immobilizer function of ecu else i would have tried it.. The closest rom would be ???
unless I'm mistaken what you need to check mainly is what you have on your car MAP,MAF,EGT piping ?
then find a car that has the same kind of MAP,MAF etc.. and use it's rom
93660005 seems to only have a MAF ?! like european cars so you need to use an EDM or AUDM rom, I'm sure there's a tephra for that
