Is this right? MUT 2byte/Evoscan
Old Mar 17, 2011 | 10:18 AM
escodotcarter's Avatar
Exclamation Is this right? MUT 2byte/Evoscan
ok, so I finally got my wideband to log with evoscan. Im using v0.99. Now my problem is getting evoscan to log 2byte load. Can someone please help me with this. I think something needs to be added to my rom XML file (88590015). I have already made the changes in my MUT table. MUT00 = 6B42 MUT01 = 6B43 I attached pictures of both my mut table as well as the portion of my XML that deals with MUT. Help would be greatly appreciated. If the attachments are to small to see please PM me your email and I will send it to you.
Attached Thumbnails Is this right? MUT 2byte/Evoscan-mut-table.jpg   Is this right? MUT 2byte/Evoscan-xml-file.jpg
Old Mar 17, 2011 | 10:23 AM
sharkm87's Avatar
1.) Ensure that you have EvoScan v.99 installed along with ECUFlash v1.3.
2.) Next, update the ECUFlash XML file located at: C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\ 88590015.xml (or whatever Evo IX ROM ID you have)
using FrontPage or other XML editor to include the following two table entries so the code ends like this:
<table name="2 byte load high bit" address="3EE86" category="Misc" type="1D" level="1" scaling="uint16" />
<table name="2 byte load low bit" address="3EE8A" category="Misc" type="1D" level="1" scaling="uint16" />
</rom>
Save the changes.
3.) Open ECUFlash v1.3 and a version 15 ROM image. Scroll down to the Misc section and you'll see two new entries: "2 byte load high bit" and "2 byte load low bit."
4.) Enter 27458 as the value for "2 byte load high bit."
Enter 27459 as the value for "2 byte load low bit."
5.) Save the ROM file. Flash the ROM onto your IX and begin logging 2-byte load using EvoScan v.99.
^^^^pic upload fail
Old Mar 17, 2011 | 10:33 AM
matt, does this look right? or put it under the mut section?
Attached Thumbnails Is this right? MUT 2byte/Evoscan-untitled.jpg
Old Mar 17, 2011 | 10:39 AM
sharkm87's Avatar
that looks fine, it will push a new table in ecuflash after you update that xml....make sure ecuflash is closed..update , save that xml..reopen ecuflash and you should see the new tabl ein there once you load in your hex file (rom)..
do the below step
Enter 27459 as the value for "2 byte load low bit."...
and then flash that rom to your car, and try out evoscan to see if its loggin 2byte load
Old Mar 17, 2011 | 10:59 AM
i followed the steps.......this is what i get.
2741.875 all the way down. car was sitting at idle, i dont know if that matters.
Also, im pretty sure i have the latest version of ecuflash and not 1.3 as the directions show. Would that make a difference?
Attached Thumbnails Is this right? MUT 2byte/Evoscan-testlog.jpg
Old Mar 17, 2011 | 03:35 PM
raasfaas's Avatar
It looks as if you haven't set the right addresses in evoscan.
The ecuflash portion looks fine, but now you need to go into evoscan's data.xml and set the addresses for 2 byte load to 00 and 01 since those are what you're using in ecuflash.
Old Mar 17, 2011 | 03:57 PM
check out my evoscan data.xml
Attached Thumbnails Is this right? MUT 2byte/Evoscan-xml.jpg
Old Mar 18, 2011 | 06:31 AM
sharkm87's Avatar
this still got me stumped and i cant let it go.... everything seems to be in order...
Old Mar 18, 2011 | 06:36 AM
sharkm87's Avatar
mm... in your mut table for 00 and 01...were you entering 0x before the values?
Old Mar 18, 2011 | 06:41 AM
yup
Old Mar 18, 2011 | 04:10 PM
raasfaas's Avatar
There has to be something that you're missing, do the other stuff work from the 2-byte thread (airflow, rpm?)
Old Mar 19, 2011 | 06:43 AM
^^^^^ didnt check. I dont think i entered the values for rpm and airflow. please tell me those a required for load to work so i can smack myself in the face lol
Old May 30, 2011 | 09:39 PM
prowakeskater's Avatar
does that XML code work for evo 8 roms? IE- my 94170015?
Old Jun 1, 2011 | 08:28 AM
Can you please also tell me why you put 27458/9 in the tables in ecuflash?
what do those values represent?
thanks
Cbr1000love
Jan 31, 2016 05:01 PM
hkumar
11
Sep 9, 2013 07:55 PM
canberkd
Mar 26, 2012 04:15 PM
EvolNinja
May 27, 2010 05:00 PM
Danieln
Apr 15, 2010 05:04 AM
