Timing map don't match logs Tephra v7
I recently switched from an unknown rom to v7 and trying to get tuned but having issues with timing. My logs are showing as much as 8* more than My high oct ig map. I flatlined the launch map and alt map to make sure it's not running on the wrong one for some reason. When I first start logging after the car warms up the timing is very close to the high oct map but after 15 minutes of doing puls and logging it just advances timing 5-8* over my map. Any ideas?
make sure the 2byte to 1byte factor is the same in ecuflash as it is in evoscan. also make sure your using the appropriate multiplier for what ever load you dont want to exceed.
