EvoX ACD reprogramming
Old Nov 8, 2011, 01:00 AM
Silver Sponsor
evoscan's Avatar
Does anyone know any threads that talk about EvoX ACD reprogramming or xmls for it?I'm pretty sure mmcflash can do it, but I want to find out for sure... does ecuflash do EvoX ACD reprogramming at all?
UPDATE: http://www.evoscan.com/technical-veh...d-abs-sawc-ecu
Does anyone have any photos of inside an EvoX ACD? Does it look the same as this Outlander one below?
Is it 512K rom size too?
https://www.evolutionm.net/forums/9722431-post35.html
MMCFlash Module 3 Read/Write
ACD Outlander XL
31036 1XG4E
8631A083
G1T32977 H 8130
SW VJF029
CPU MH8104F
Download 8631A083.bin (512K)
Old Nov 8, 2011, 03:21 AM
Robevo RS's Avatar
Try to pm Vgergo : https://www.evolutionm.net/forums/me...14-vgergo.html
I know the guy from hungary, he does tunes rally cars and serious race cars, there for if there is a solution and program for it he has it.
Rob
Old Nov 8, 2011, 06:49 PM
tephra's Avatar
yes EcuFlash does it.
no there aren't any xml's for it
yet
Old Nov 8, 2011, 10:42 PM
EvoM Community Team
fostytou's Avatar
We posted some pictures and chip information in the other ACD tuning thread from my car.
https://www.evolutionm.net/forums/8284214-post286.html (and some other posts also)
As far as I know there hasn't been any development on it.
Old Nov 9, 2011, 02:54 PM
Golden's Avatar
yet
Does EcuFlash read it with the current version, or do you need something special?
Old Nov 9, 2011, 05:39 PM
tephra's Avatar
you need to bench it...
Sabin doesn't want the details revealed at the moment
Old Nov 9, 2011, 08:39 PM
Golden's Avatar
Are you able to read the code that runs the display? I'd like to change that up.
Old Nov 11, 2011, 11:03 AM
Silver Sponsor
evoscan's Avatar
yet
have you confirmed that ecuflash can write back to the ecu too? I am getting people buying mmcflash because they said its the only program that can write back to the EVoX ACD ecu. And many people are searching for ACD xmls for it at the moment.
do you know if ECuflash can write back to the ecu? if so, do you have to bench it? or can it be programmed via the OBDII CAN port?
Old Nov 11, 2011, 11:06 AM
Silver Sponsor
evoscan's Avatar
I posted the Outlander ACD bin 512k file above.. do you have a copy of the EvoX bin file too? and is it also 512k?
Old Nov 11, 2011, 11:10 AM
Silver Sponsor
evoscan's Avatar
well there were many people that didn't want the details of how to bench recover a EvoX ecu posted neither... but I posted up pictures and wiring diagrams.
Old Nov 11, 2011, 03:01 PM
Beeble's Avatar
There is a Ralliart ACD ecu available for the X
It only works for the RS models though ... so not compatible with AYC.
It would be nice to compare and contrast the roms though
I would certainly fork out some $$$ for reprogramming for road racing with someone who knew what they were doing.
Old Nov 11, 2011, 03:27 PM
Robevo RS's Avatar
i have a GEMS ACD ECU and that is actually working right now in my car with AYC with 5 maps i can choose form ...
BUt i dont know tht will actually work with a stock Engine ECU. Probably yes, but i am not sure.
these are the specs
" The EVO ACD is a direct replacement for the factory unit making it a perfect option for group N rally series cars.
Fully customisable differential maps
Setup can be password protected
Wheel speed sensor diagnostics
Fits into standard EVO wiring
Uses all standard EVO sensors
Connects to GWv4 software for complete customisation
5 Modes of operation: Off, Gravel, Snow, Tarmac, Lock
Start, Handbrake, Footbrake, Accel, Deccel
regimes for each active mode
Serial data stream for dash display
Available for Mitsubishi EVO models 7-10
Old Nov 13, 2011, 07:24 PM
tephra's Avatar
actually I did...
Old Nov 14, 2011, 03:24 AM
Silver Sponsor
evoscan's Avatar
actually I did...
yep that was funny, Colby made a guide, it was accurate but was not quite simple enough for peopleto follow, so you made a guide, but people couldn't find it, I was getting lots of questions on it, including tuners telling me not to release the guide, so I made a guide too and posted it on my website
Old Nov 14, 2011, 03:29 AM
Silver Sponsor
evoscan's Avatar
I'll ask him why he doesn't want it released.
Quick Reply: EvoX ACD reprogramming
