Is this a good tune or a n00b tune, please scrutinize (ROM included)
Hi guys,
This ROM came with my AUDM EVO 8, previous owner paid a lot for it from a tuning company known for dodgy dyno figures.
My car doesn't have a wideband or a JDM MAP etc. for boost control and AFR monitoring so not sure how they measured actual boost when they tuned it.
Apparently tuned to 22psi according to receipts and making 203KW ATW on a dyno (again, company is known for dodgy dyno figures).
Problem is car is wasting a full tank in 186 miles or 300KM, not sure how rich it is running as I have no wideband as previously mentioned.
Any advice/recommendations. Does the ROM look right or is there dodgy **** in there?
This ROM is tuned for a stock boost solenoid, correct? Any problems if I flash a stock EVO 8 ROM in there, I'm not sure if the boost pill has been changed etc, do any of these ROM figures suggest that this may be the case?
If you guys need EVO Scan logs I can post shortly, any suggestions on what to log?
Thanks a lot in advance, I'm optimistic about fixing this up myself so any advice would be appreciated.
EDIT: EvoScan log now added as requested.
Um, I not an expert on all this but I've spent the last month or so tuning my Evo 9 with help from Merlin's guide and I can say that your rom looks crap. Both the high and low octane maps look VERY basic and wrong, I had a quick look at the boost and it looks strange too. Also your timing looks weird. Four things to do, buy a A/F sensor and gauge, get your hands on Merlin's guide, log, log and log some more with evoscan (log for knock but your fuel maps look too rich) and pay someone to tune your car, I've heard good things about http://www.vr-speed.com. Good luck
By the way where is Aus are you?
I'm sure TS comp are good too!
i wont comment on the maps until i see a log of the actual car.
3rd gear pull start it at 2000 stop at 7500. rename csv to txt and upload evoscan
log file to forum
[quote=tscompusa;9905858]lol i tuned all the cars you see saying vr-speed tuned..
Oh, fair enough.
I was looking at the OP Hi octane fuel maps, I've never seen a tuned map where the whole 10-80 load is set at 14.7 right across the whole rev range and having whole load columns all basically the same number. ? . Don't know much but that looks strange to me.
Oh, fair enough.
[QUOTE=Fireescape;9905865]
ya i want to see the log.
that block does nothing tho.. in between shifts you may trace over there and go lean, but thats about it.
i dont like to judge maps like that style timing map without knowing what loads the cars hitting.
the fuel map is most likely going to spool way to lean tho based on how its mapped.. again its not smart to judge it until you see the log though.
Oh, fair enough.
Oh, fair enough.
The OP probably gone to bed, it's 1am here . After I get my exhaust, 3 port, A/F, walbro and licp installed I'll get in contact Tom and get you to do your magic on my car. I'm enjoying the challenge of self tuning but time is scarce and the learning curve is a bit steep. Cheers
Thanks for that.
Is the ROM tuned for the stock boost solenoid? Also, is there anything in the ROM's boost values that suggest that the boost solenoid may have been modified (pills etc.).
Thanks!
Thanks!
scheides
Oct 22, 2021 08:59 AM
EvilDSM97
E85 / Ethanol
12
Nov 4, 2015 04:49 PM
lathiat
Sep 1, 2015 09:58 PM
