V2.9 evoscan shift data to left into logging note header is normal
I'm running donners 88586714 DMA live map sd 2.0 based on v7
I noticed that making wgdc adjustments about a week or two ago somehow corrupted that flash. I copied the tables over to a fresh rom and have been tuning ever since. Donner reduced the ve table to make room for sd. However the issue he described that would be the problem is not what's happening if alt map space ate the sd table or something like that.
I can try a quick flash of a 88592715 rom I might have. It's untuned for this set up but a quick log would show positive or negative
Mrfred I have flashed a couple times again same issue. I will try an older version of my rom to see if this is corrupted again
Fox- als testing is tough. I have put very silly values in silly tables over the time I've done this. If reliability like this will be a problem then maybe a real ecu/ems is my destiny.
I wonder if the ecu is damaged, can it be repaired?
Ot but sas als related
Either way Todd is donating a valve I presume is from a cosworth with remote housing to me and I'm going to ground that relay so it opens upon sas tables.
I was practicing last night and what ends up being the case, bear in mind I have a bov vta. Lift -slight pause of vacuum, sas provides fuel after pause, makes the switch to alt maps, and my mani sees 4-6 psi with 30% tps . Mean while my bov is screaming
That's because only a hand full of people had to flash that many times, including Ratsbud who's been working on the ALS project.
Based on a similar experience I had, I think the ecu is beyond repair
Ratsbud, sounds good in regard to the cosworth valve, do you have a picture of it? post it on the als thread.
The flash memory where the rom is stored is what can go bad. It looses its ability to retain the data or possibly not provide the correct value when requested by the processor. I think the tephra roms have the potential to be more problematic because every time the ecu is flashed, the entire rom is rewritten to the flash memory. The factory rom only flashes the first 100 kilobytes or so where all the factory tables are stored. I would think that if the flash memory were going bad, ecuflash would give read/write errors.
Well by rearranging my logging items carefully I can get by with everything shifted one column to the left into log notes.
Will have to do for now
Ill keep checking too maybe something in my cable went bad? Funny how both laptops and both versions experience the same issue. Leads me to 2 other paths.. Ecu & op cable.
I need to find another Mitsubishi to log!
Good luck man, keep us updated
