AEm 30-2301 Non-Linear formula
I recently hooked up my AEM in-line WB O2 and have it running via pin 75 directly to EvoScan. Reading loooked odd so I started digging around. I found that the signal is non-linear on this model. I found info that other tuning platforms have susessfully logged using polynomial equations:
http://forum.efilive.com/showthread....n-Linear/page3
The equation used is:
((((0.0298)*{EXT.AD1}-0.1826)*{EXT.AD1}+0.4971)*{EXT.AD1}+0.5253)*{EXT.A D1}+8.4433
What is the referance ext.ad1? Is there a way that I can plug this into EvoScan?
Already did. Hoping that someone else has had the same problem and solved it or that there is someone smarter that me (not hard) that can make heads or tails out of the code string. I am betting that "evoscan" is busy enough already without my one off problem.
mrfred
Dec 27, 2016 09:26 PM
burner67
Lancer Aftermarket Forced Induction Tech
Jul 8, 2011 11:20 AM
