Disable P0125?
Disable P0125?
Is there a way to disable this code? I keep getting it recently. I dont see it in my periphery list on the 965xxxx rom.
I do have my rear o2 disabled in the periphery bit to turn off LTFT. If i must turn this back on to get rid of the code is there another way to disable LTFTs?
after searching i found this:
<table name="Closed Loop - LT Trim Control" category="Fuel Trims" address="35e5" type="2D" level="2" scaling="LT Trim Hz">
<table name="Conditions" type="Static Y Axis" elements="4">
<data>Low -> Mid</data>
<data>Mid -> Low</data>
<data>Mid -> High</data>
<data>High -> Mid</data>
</table>
</table>
Can I change the values in this table to unreachable numbers to disable fuel trims? What will that affect if i do that?
</table>
</table>
Biggiesacks
Oct 13, 2016 02:37 PM
