Need explanation for 1b load readings
Come to find out, the drivers didnt install correctly. One of them did, allowing me to log however whenever I went WOT it shut down. Very weird. I uninstalled the drivers via device manager when it was plugged into the car, uninstalled, unplugged, plugged back in and pointed to the ecuflash folder, and BAM, it worked. Hopefully this helps someone out one day.
your load numbers are only dropping down cuz the load 1b only actually goes to 255 * the mulitplier of 1.2 that it was t which gives you a max of 306 and anything over that started back at 1. so where your load said 30 and your at wot, its actually reading a load of 336 ish. I'm not 100% on that but from what ive noticed, that seems to be the case.
ptm5070
Dec 18, 2014 09:06 AM
Pitside
Apr 29, 2014 04:02 PM
