Load Logging
Load Logging
Evo 9 EDM
Rom :88840017 --- tephra 5.5
When I try to log load with Evoscan V2.9 the load 1Byte is always "0" zero.
I searched and I couldn't find anything related to my rom version but it's mentionned that I need to modify the MUT table but ... what , where ... .
Please advise
Please advise
To begin with "Merry Christmas to all".
Then you can find attached my MUT table and in the link you've sent me you can find that i should change:
88840017
2byte load
MUT 00 = 6B22
MUT 01 = 6B23
2byte RPM
MUT 02 = 6AFE
MUT 03 = 6AFF
2byte AirFlow
MUT 04 = 6B7E
MUT 05 =6B7F
My questions are:
>> I f you look at my MUT table you can find that the bMUT 00 is FFFF , what should I change .I tried the MUT 01 the values are wrong while logging.
>> To log load should I change the RPM and Airflow or only load?
I need your help cause I'm facing lots of knock and I need to do it the right way.
Thanks in advance for your help or suggestions.
88840017
2byte load
MUT 00 = 6B22
MUT 01 = 6B23
2byte RPM
MUT 02 = 6AFE
MUT 03 = 6AFF
2byte AirFlow
MUT 04 = 6B7E
MUT 05 =6B7F
My questions are:
definition file is incorrect for the static values for mut
it should read -0-1-2-3-4-5- etc
remove current and add this to the evo9 Base xml
<table name="MUT Table" category="MUT" type="3D" level="2" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
