Hitting Boost Cut On MBC
Old Mar 1, 2018, 01:26 PM
TariqEvo's Avatar
Exclamation Hitting Boost Cut On MBC
So I am currently using a Hallman Pro RX Manual Boost Controller, and I am hitting boost cut everytime I exceed something around 320 load
This is what my boost limit table looks like. Why are these values in percentage, is there anyway I can change them to load?
Note: My car has only a MAF sensor and no MAP sensor
Old Mar 1, 2018, 03:01 PM
RightSaid fred's Avatar
Check your IDC.....it'll be too high.
Old Mar 1, 2018, 07:34 PM
400s's Avatar
Tariq... if you have not played around with your maf scaling then 320 load is well over 2 bar
the values you see there are load values... 230 translates to something like 1.3 or 1.4 bar...
thats why why you are hitting boost cut...
Old Mar 1, 2018, 08:43 PM
TariqEvo's Avatar
I have not played with my maf scaling, its completely how it is from factory, except that I am running a K&N intake,
Also, if those are load values, how come I am hitting the cut at 320 rather than 230?
Old Mar 1, 2018, 08:45 PM
TariqEvo's Avatar
How do I know for sure it is high?
Old Mar 1, 2018, 08:46 PM
TariqEvo's Avatar
Update
This 320 load where it hits boost cut is 23psi on the boost gauge
Old Mar 1, 2018, 09:54 PM
Because you got fuel cut.
You'll see it on a data log.
Thugline
17
Apr 26, 2010 04:42 AM
ebbeast2005
13
Oct 7, 2004 01:02 PM
DynoFlash
Oct 29, 2003 09:40 PM
Quick Reply: Hitting Boost Cut On MBC
