Which is safer for DD?
Old Apr 14, 2009 | 08:47 PM
detroit pistins's Avatar
running a stock 9 turbo at a high psi such as 28-30psi with meth or run a bigger turbo(red) at 22-24psi to achieve 400/400?
Thanks
ofcourse with stock internals and the usual basic supporting mods such as
1) tbe
2) inatake
3) ic piping
4) 02 housing.
5)fuel pump
6)injectors
7) fmic + piping
Thanks
Old Apr 14, 2009 | 08:48 PM
MattevoVIII's Avatar
im interested in hearing that one too♠
Old Apr 14, 2009 | 09:19 PM
Venividivichi00's Avatar
subscribed for possible answer
Old Apr 14, 2009 | 09:23 PM
punker462606's Avatar
Don't hold me to it but I would think the "red" with less boost because if you run high boost with the stock evo 9 turbo your going to be running past its efficency and you could blow your turbo which can get into the motor and break something. Please correct me if i'm wrong.
Old Apr 14, 2009 | 09:59 PM
BenJ's Avatar
The safer route given the ones you listed would be the red. It's not so much that running the stock turbo out of it's effeciency range will cause it to fail, as it is the increased pressure can cause a laundry list of items to fail in your motor.
Old Apr 14, 2009 | 10:04 PM
Well put.
Old Apr 14, 2009 | 10:35 PM
krisdlm's Avatar
subscribed!
Old Apr 15, 2009 | 05:26 AM
great comments guys thanks.
lets hear from the venders that have been cranking 700whp +, lets see what they think with regards to reliability.
thanks
Old Apr 15, 2009 | 11:27 AM
anyone?
Old Apr 15, 2009 | 12:22 PM
Jp7's Avatar
Jp7
Too much backpressure with the stock turbo... you would have to tune very accurately.
Old Apr 16, 2009 | 07:18 AM
I think ur reffering more to damaging the turbo with the resulting backpressure of running higher psi. I was thinking more of what is safer for the engine. in terms of pressure, generated heat....etc
I would like to be in the 400 range, however, I am trying to do it as safe as possible, even tho it might cost me another $1500 to upgrade the turbo, but i would rather do it safe and trying to research it and see what everyone thinks before i pull the trigger.
thanks,
Old Apr 16, 2009 | 01:51 PM
bump
Old Apr 16, 2009 | 06:11 PM
Jp7's Avatar
Jp7
thanks,
no, what I meant was that having an engine that feels more backpressure is not safe because the tune cant generate as much power because it is more likely to knock due to that backpressure.
The tune is what gives you the power, the mods are only power enable'ers.
Old Apr 16, 2009 | 06:22 PM
I understand that the higher the pressure, the lower the ignition temperature point, the more often u experience knock.
but so ur saying going with a bigger tubo and run it at a lower psi is safer? i would agree with u .
Old Apr 16, 2009 | 08:30 PM
evosam726's Avatar
bro im in the same situation as u and i got the red...but i dont got meth lol
