Evo 8 to 9 engine swap
Old May 29, 2009 | 07:12 PM
SPC Perrault's Avatar
Before I spend the $$, I was wondering if all you need to make a Evo 9 engine run in an 8 is the engine wiring harness and ecu?
Old May 29, 2009 | 07:51 PM
Tonba's Avatar
Im interested in this too.
Old May 29, 2009 | 08:01 PM
jdmeurorlude's Avatar
if you are going through all that trouble just use aem ems. my .2
Old May 29, 2009 | 08:10 PM
Zodiac13's Avatar
i think so but keep checking or ask the guys at gsc.
gsc evo 8.5
https://www.evolutionm.net/features/article.php?id=113
Old May 29, 2009 | 08:13 PM
Tonba's Avatar
I would like to use stock ECU
Old May 29, 2009 | 09:16 PM
billyblonco's Avatar
I think you would need a 9 ecu to control the mivec.
Old May 30, 2009 | 12:06 PM
chrisw's Avatar
mechanically, it's a bolt in affair, nothing out of the ordinary.
in addition to the long block, you need the engine bay wiring harness and ECU for the upgrade.
Old May 30, 2009 | 12:09 PM
shh!! sleeping's Avatar
+1 id like to know
Old May 30, 2009 | 02:20 PM
Thats what I figured, the ecu and wiring harness are the biggest deal, I guess im going to go ahead and do the swap
Old May 30, 2009 | 02:23 PM
griffeyr's Avatar
but why do u want to do this???
Old May 30, 2009 | 08:51 PM
silver_03_evo's Avatar
if you need a harness i have one
Old May 31, 2009 | 08:56 AM
Well griffeyr, I want to do this cause my current engine needs an overhaul.. so I figured well im rebuilding that engine (probably going to build it into a 2.3L) I might as well have another that I can use well im building the other.
And how much did you want for that ECU and wiring harness?
Old May 31, 2009 | 02:53 PM
Tonba's Avatar
Im also interested in doing the swap as I need to rebuild my 2Ltr Evo 8 motor anyways, so why not get a 2.2L mivec longblock and drop it in? =D
Although, I would want to run the standard EVO 9 Ecu..
How much would I be looking at the harness + ECU?
Old May 31, 2009 | 08:31 PM
Tonba
I have found on ebay used 9 engines for around 4000 and complete wiring harness including the ECU for 500. So anywhere between 4-6K used. Brand new I found 9 engines at lancershop.com for 6000 and the harness and ecu for 1700.
Old Jun 7, 2009 | 10:39 AM
Monochrome's Avatar
You keeping your EVO8 tranny & turbo?
