Stock boost on an Evo 6/TME?
Old Oct 24, 2003 | 12:23 PM
turbopanda's Avatar
Exclamation Stock boost on an Evo 6/TME?
Just curious, what is the factory boost setting for an Evo 6 and Evo 6 Tommi Makinen Edition? I'm wondering whether my car is boosting more than it should be, since everyone tells me its unusually fast for a stock Evo 6.5... thanks
Old Oct 24, 2003 | 12:24 PM
eldanoloco's Avatar
Did you try to use Google?
Old Oct 24, 2003 | 12:42 PM
turbopanda's Avatar
I've searched everywhere, and haven't been able to find my answer
Old Nov 5, 2003 | 08:58 AM
greek_evoVI's Avatar
it sould be 1.1 bar overboost with 1 stable but it's not always the same for every car....
my car (rs2) goes to 1.3 with just an induction and exhaust.
when my car was completly stock i run 1.1 the same boost with my friends TME , but i was faster than him , so it's not only the boost that makes the difference
Old Nov 5, 2003 | 12:00 PM
turbopanda's Avatar
OK so that's stock boost levels for the TME, how about for a stock Evo 6 GSR?
Old Nov 6, 2003 | 08:44 AM
it sould be the same. the difference is in the turbo. the TME uses the RS-RS2 titanium-alloy turbo and it spins faster , almost 500rpm before the GSR
Old Nov 6, 2003 | 01:53 PM
turbopanda's Avatar
Are you sure its the same? Because I heard that the Evo 6 RS has higher boost than an Evo 6 GSR. I would imagine that the TME would have the same boost levels as the RS, if not greater.. but if its supposed to be boosting at around 1 bar, then I guess I have a problem with my wastegate actuator, because my TME only boosts between 0.7-0.9 bar. Time for a boost controller?
Old Nov 7, 2003 | 02:42 AM
YES....
Old Nov 7, 2003 | 04:19 AM
turbopanda's Avatar
ok thanks, I appreciate the help
Old Nov 22, 2003 | 08:49 AM
BadBoyBeltran's Avatar
You have to ask people in the MLR forums about the TME since we do not have it. From what I heard its 1.1 bar, which is 15.95 psi. Get a boost controller if you want to raise the boost. You can raise it to 20psi or around 1.4 bar easy. Anything higher you need to retard timing up top to avoid detonation.
Old Jan 12, 2004 | 09:23 AM
ChrisEvo6's Avatar
my Evo 6 gsr boosts @ 15psi i think thats about 0.9 to 1.0 bar
should be the same with the T.M.E?
Old May 15, 2004 | 10:08 PM
sethor's Avatar
1 bar = 14.7psi
iam sure the standard ecu on the 6.5 cuts out at 1.2 bar
in the 6 only the rs and rsII had the titanium-alloy turbo
with the 6.5 the gsr,rs and rsII had the titanium-alloy turbo
Old May 16, 2004 | 01:27 PM
evo_artist's Avatar
TME is set at factory 1.2 Bar
I saw 1.1 also soif you boost in those levels without mods, its acceptable
Old Mar 8, 2006 | 09:03 PM
ralliartevolll's Avatar
mine boosts stock right about 17psi
Old Apr 7, 2006 | 06:12 PM
racetek1's Avatar
undefinedundefinedStock boost on the TME 1.29 bar or 19 PSI on the EVO 6 is 1.08bar or 16 PSI
nspyr
26
Jun 20, 2017 02:08 AM
EvolutionRon
May 11, 2017 05:11 PM
Fastone_evo6
Jan 27, 2012 10:04 AM
Boost Solutions
Nov 18, 2003 12:43 PM
