E70, BR 2.3 and some nice power.
The fuel pressure regulator on this car is still stock. I didn't want to change it until I had to, right now we are safe.
The IDC is going to jump up quite a bit when the car gets pure E85 in it, I'd guess around 15%, that's going to put the IDC's in the mid 90% range.
Sorry for all the questions its just that this is where I am focusing my purchasing right now on my fuel system , and you know that I want to run E85 as my primary fuel and I am set on pushing that FS635 as far as I can on it.
I got a E85 pump just minutes from my house
The rail that is available right now that we are talking about is only available with -10 inlets/outlets.
The E70 is pretty good, better than 94 octane and alky............not sure about that.
Two Wilson rails will be available one 11/16 and the D Rail. They will be available with fittings to work with the stock lines and also AN lines. The D Rail holds 15% more volume than the 11/16 rail. It will be a direct bolt on kit with nothing else to buy. The 11/16 rails will be available in about a week. The D Rail shortly after. This is the first prototype D Rail. The production rail mounts will be billet. These were built with the E85 guys in mind.
