FP HTA88 or HTA37r dyno sheet.
didnt you have a gt40r on before? can be as laggy as that
I did but the turbo couldn't make anymore power than 672. It was old technology when I bought it where as this turbo is newer.
Nah the 4088 spooled fairy quickly actually. Full spool by like 5500 or so.
Now don't get me wrong the 3794 hit full spool late 6200'ish but it starts around 3000 and the ride up to 8500 is a fun ride.
I don't drag race so it does perfect for what I want.
Pressure is what spools a turbo, but too much up top will kill power. I have no idea why there hasn't been a turbo designed that has a hot side housing that changes volume. Only one I've seen of course is designed by Acura.
http://www.acura.com/interactiveshow...ormance_engine
Of course there's no point in spooling a turbo when the dynamic compression and flow velocity of big cams is crap down low.
Then again if we had variable lift/variable timing and a turbo that spooled at 2000 rpms, it's not good to put that much load at that low of rpm. Timing would have to be -5 to -10* lol.
Stock appearing turbo's need as much wastegate as possible to keep from suffering on the top end because the exhaust housing is tiny.
At what rpm do you cross 20psi?
Yeah, I agree, Bostonhatcher. Thats why in my original response in post 17 of this thread, I referred specifically to "this turbo." This big boy was probably still within its efficiency envelope way after the engine is past its power peak. In the case of this particular turbo on that particular engine a gate would not produce any more power.
Boston, I am not gonna comment anymore on this thread about wastegates. I dont wanna make anymore off topic discussion, buddy. I do find the topic interesting and you can PM me if you want. Take care.
I could swap a new A/R but this turbo is pain to put on. The fitment of them is horrible and it took 8 hrs to get it to fit correctly. FP said I was the first person to order the twin scroll edition from them.
I like where it's at. I don't drag race at all, just take it out when I want to have some fun.
David Buschur
Sep 6, 2015 09:27 PM
David Buschur
Evo X Dyno Results
32
May 13, 2010 03:56 PM
David Buschur
202
Oct 3, 2008 12:09 AM
David Buschur
267
May 15, 2008 11:27 AM
David Buschur
271
Jul 3, 2007 10:00 AM
