Additional dyno testing of the BR EVOX T3 turbo kit
Old Mar 30, 2010 | 10:47 AM
David Buschur's Avatar
Last Friday I put some more time in on the dyno to try and make a little more power and mostly work on seeing just how quick I could get the new turbo kit to make boost. I spent quite a few hours running the car and making changes to the MIVEC and the rest of the tune.
In the end I could not be happier with the results.
The engine is our Stage 3, stock compression, standard bore 2 liter engine. Stage 3 head with Cosworth MX1's. The car is being run on Shell 93 octane and nothing else. The turbo is a Blouch GT600R, which is a billet 62mm compressor wheel with a GT35r turbine wheel. I am using an .82 a/r turbine housing. The exhaust from the outlet of the turbine housing to the muffler where it transitions to twin 2.5" outlets.
I am also using our standard BR inline manual boost controller.
The spool up is utterly amazing and I attribute it to the header design and of course the tuning.
This is a short dyno pull from 3000-6000 rpm, 4th gear. As you will see I printed the hp/torque down one side of the sheet and the PSI on the right side. This combination reached 20 psi at a simply amazing 4059 rpm, that is from the sheet and the datalog.
This next sheet is the finished tune and the last 3rd gear pull I made. The pull was from 3000-7700 rpm. While the torque is not insanely high it is very flat and I can tell you this car pulls like a freight train on the road. Peak boost was 28.3 psi, peak power as you can see what 517 whp. The minimum psi during the pull was 3.8 psi at 3,000 rpm and by 4230 rpm the car already at 20 psi.
The car is ready for the track now and as soon as they open up, delayed now from being too wet, we are going to get it out and make some passes with it. I feel there's a mid 10 second pass in it at 130+ mph on just pump gas.
These turbo kits are finished, on the shelf and available for shipping.
Old Mar 30, 2010 | 06:22 PM
omni-star's Avatar
Great Results David!!!
Old Mar 30, 2010 | 07:13 PM
E-SPEC INDUSTRIES's Avatar
Wicked spool-up!
I have my eyes on this kit for a particular power hungry customer... Looking forward to the mph results!!
Old Mar 30, 2010 | 08:03 PM
futurevowner's Avatar
I wouldnt doubt seeing 135 traps knowing your dyno, nice kit all around.
Old Mar 30, 2010 | 08:41 PM
scheides's Avatar
EvoM Moderator
Awesome! How do you like tooling around town in this thing, compared to the old dom2 setup?
Just read through an old post of yours today:
https://www.evolutionm.net/forums/ev...ion-parts.html
Old Mar 30, 2010 | 10:45 PM
4drboost's Avatar
Can I use this turbo kit on a X MR Touring?
Old Mar 31, 2010 | 08:05 AM
scheides,
As far as driving around town, I have to be honest, it's the first big turbo kit i like. The car feels great, obviously not quite stock turbo/Dominator/Red but it's damn close given the 20 psi at low 4,000 rpm.
4drboost,
I know of no reason for this kit to not work on any EVOX.
Old Mar 31, 2010 | 08:28 AM
Heat control.........it's a real tough job on the EVOX. We've added the full BR exclusive DEI downpipe blanket, T3 turbine housing blanket and now I've built a new SS shield for between the header and firewall insulation.
Here are some pictures of it. This will come standard with all the turbo kits, there is no increase in the kit pricing.
Old Mar 31, 2010 | 11:01 AM
JesseB's Avatar
looking good!
HR2L's Avatar
Looks nice! Great Job BR!
Old Mar 31, 2010 | 11:10 AM
MrHouse's Avatar
Sweet job!!
Old Mar 31, 2010 | 12:20 PM
whitecomet's Avatar
nice
Old Mar 31, 2010 | 09:05 PM
Hiboost's Avatar
Lightbulb Buschur nailed this one!
I'm still amazed what kind of spool and response you are getting out of such a large turbo on the Evo X! Since you did a 4th gear pull on a Dyno that seems to be very closely calibrated to the STM mustang dyno I decided to do a "close as I can get it" overlay of a recent dyno session. It's not perfect but I lined up the peak numbers at approximately the right RPM's and of course at 5252 rpm the HP and torque curves will cross. I'm looking at e85 and slightly more boost to bump my numbers a bit more but I'm never touching that steep of a climb to 517 whp without more mods and a bigger turbo. Sweet MIVEC tuning there!
Pretty damn amazing since I get 20 psi by 3500 rpm on the street in 4th gear, and on the dyno due to less load that occurs around 3800 rpm. For Dave to achieve 20 psi just over 4000 rpm in 4th gear on the dyno is freakin amazing for such a large turbo!
I would be so all over this kit if I had to do it again, engineering the heat shield for the header and keeping the price the same was a cool thing to do as well. I'll be doing a post of my recent dyno testing soon as well.
Old Apr 7, 2010 | 04:57 PM
bambooi's Avatar
When are you going to take it to the strip? Is it open yet?
Old Apr 7, 2010 | 06:07 PM
bandit09's Avatar
MMM lookin forward to seeing this thing run some 10's
