Official 3rd gear Street Pull - Data Thread
Old Jun 1, 2009 | 10:13 PM
evowario's Avatar
Nice charts
Old Jun 1, 2009 | 10:55 PM
evokid511's Avatar
E85 on 30 psi with mods in sig form a 3rd gear pull
Old Jun 2, 2009 | 09:06 AM
partyboy1122's Avatar
BR Cast 3065
HKS 280s
PTE 1000's
4'' FMIC
23-24psi
93Octane
Stock 2.0
Was done on Stock Clutch. Burnt it to crisp at the track.
New clutch in today, and will continue Tuning.
Old Jun 2, 2009 | 11:33 AM
XracerS13's Avatar
Definatly some good data. This is really useful for comparing spool up times with different setups. What kinda data logging software/systems are you guys using?
Old Jun 2, 2009 | 11:43 AM
jid2's Avatar
Most guys run Evoscan for the datalogging and Data Log Labs to create the HP/TQ graphs from the Evoscan data.
There are excel spreadsheets and other ways to do it, but DLL is pretty much click and go.
Old Jun 2, 2009 | 12:36 PM
Aby@MIL.SPEC's Avatar
Nice thread
evo 8
stock bottom end / cyl. head
cosi m2 @ +2in/0exh
fp-red w-fp w/g act.
MR bov
MIL.SPEC ported exh mani, hotside, LICP, 3" DP, 65mm tb
weapon R int. mani
91 octane
aem ecu w/MIL.SPEC tune
This is some early data with the red, as i am at work & have limited data here....hence the wavy boost.
Old Jun 2, 2009 | 06:51 PM
JohnBradley's Avatar
Here is the full .csv log of a 3582HTA on pump. This was a 3rd gear pull from pretty low to get the fullest log possible, the car has been converted to SD. It is a 9:1 2.0L with ported head and GSC S2s.
Old Jun 2, 2009 | 07:05 PM
FathouseFab's Avatar
Mr. Bradley, converted to SD with the stock ecu patch? If so how is that working out for a "bigger" power setup?
Fathouse
Old Jun 2, 2009 | 09:51 PM
jid2's Avatar
Here's the graph for the pump gas 35R JohnBradley posted. Can you say flat torque curve!
Old Jun 2, 2009 | 11:06 PM
Thanks for converting that to a DLL graph, here is my version
Old Jun 2, 2009 | 11:09 PM
Fathouse
Not to get terribly off topic, but my car has been SD for a long time. This is a customer car actually. I am going to stop using the Pro in my car and go to straight ECU speed density shortly though.
aaron
Old Jun 3, 2009 | 01:51 AM
burnzy's Avatar
tomei arms with 50/50 meth HFS-5, stock block. 27psi vs 30psi, second run was started late hence it looks laggy. 27psi was bov leaking, 30psi was crushed bov.
Old Jun 3, 2009 | 08:22 AM
jid2's Avatar
Aaron, can you guess the weight of that customer car? I used the info I have for my car which is 3100 lbs without driver. The DLL numbers would be higher if that car was heavier
Old Jun 3, 2009 | 08:32 AM
Lucas English's Avatar
The car is full weight so I would think around 3400-3500lbs with driver.
Old Jun 3, 2009 | 08:33 AM
Not sure if it matters on your chart but we are reving to 9k.
