My E85 DYNO Evo_9 Stock Turbo
Subscribe
Apr 10, 2009 | 02:16 PM
everyone says oh upgrade the stock IC...im really not for it unless you guys are going to do some serious road racing or run after run on the track your fine with the stock IC until you upgrade the turbo...goodluck and very nice numbers.
Reply 0
Apr 12, 2009 | 06:38 PM
i want to make 400 sooo bad on my 9 turbo i ported everything and i have 4inch core lol
i will do it
Reply 0
Apr 12, 2009 | 06:39 PM
Quote: i want to make 400 sooo bad on my 9 turbo i ported everything and i have 4inch core lol
i will do it
Funny thing is 400awhp gets boring fast. lol
Reply 0
Apr 12, 2009 | 06:55 PM
yup^^^lol
Reply 0
Apr 12, 2009 | 08:39 PM
Nice power!
Reply 0
Apr 13, 2009 | 05:47 AM
Did you get a chance to run the car? I can't wait to get mine tuned next month, i have the stock 8 cams though so that will kill my top end.
Reply 0
Apr 17, 2009 | 10:25 AM
Nice numbers man!
Reply 0
Apr 17, 2009 | 10:34 AM
These numbers are nice, but you proly wouldn't hit 400 on a mustang dyno. Also you see how your boost is dropping at like 4400 Rpms and keeps falling, get a new BOV recir and you will hold boost for longer.
Reply 0
Apr 17, 2009 | 10:43 AM
Quote: These numbers are nice, but you proly wouldn't hit 400 on a mustang dyno. Also you see how your boost is dropping at like 4400 Rpms and keeps falling, get a new BOV recir and you will hold boost for longer.
On a Mustang dyno it would be around the 350awhp range.
Reply 0
Apr 17, 2009 | 11:36 AM
The boost will drop off as the turbo runs out of steam in the higher rpms. A IX will usally taper to 22-23 lbs by redline. I'm not sure how soon it starts though.
Reply 0
Apr 17, 2009 | 12:23 PM
Quote: A IX will usally taper to 22-23 lbs by redline.
According to Mike @ AWD the boost will hold longer with an 02 dump and HP actuator. I will be getting both items to see if he is correct. He said the taper should be 3-4psi with those items, so if I ran 30psi I should see 26-27psi at redline if he is correct.
Reply 0
Apr 17, 2009 | 01:16 PM
Quote: According to Mike @ AWD the boost will hold longer with an 02 dump and HP actuator. I will be getting both items to see if he is correct. He said the taper should be 3-4psi with those items, so if I ran 30psi I should see 26-27psi at redline if he is correct.
Wow, that would be crazy, from what i've seen a FP red will hold that but not a stock turbo. Let us know if it works though
Reply 0
Apr 18, 2009 | 11:43 PM
that is sick numbers
Reply 0
Apr 19, 2009 | 12:47 AM
Best I could get with my 04 RS on E85 with a IX turbo on 30 psi was 395hp, on a Mustang dyno. Uncorrected was 389. Tried everything to keep the boost from dropping to 22 psi. Best I can get it to hold is 23 psi at 7500. Stock motor. Cams. Stock intake and TB. BR exh, Race core, lower pipe. Stock upper. Pump, 1000's, ported manifold, Ebay O2 housing.
I have tested a few of the O2 dumps, four different heavy WG canisters. Regardless of what people advertise or claim. Have yet to see anything that will make a IX turbo hold 26-27 psi from a 30 psi peak. Turbo dies off up top period. Most cars drop to 20-21-22 if you are lucky.
Reply 0
Apr 19, 2009 | 07:11 AM
Quote: best i could get with my 04 rs on e85 with a ix turbo on 30 psi was 395hp, on a mustang dyno. Uncorrected was 389. Tried everything to keep the boost from dropping to 22 psi. Best i can get it to hold is 23 psi at 7500. Stock motor. Cams. Stock intake and tb. Br exh, race core, lower pipe. Stock upper. Pump, 1000's, ported manifold, ebay o2 housing.
I have tested a few of the o2 dumps, four different heavy wg canisters. Regardless of what people advertise or claim. Have yet to see anything that will make a ix turbo hold 26-27 psi from a 30 psi peak. Turbo dies off up top period. Most cars drop to 20-21-22 if you are lucky.
+1
Reply 0
