My E85 DYNO Evo_9 Stock Turbo
Old Apr 19, 2009 | 08:54 AM
  #31
1QYK9's Avatar
Originally Posted by Early EVO
Best I could get with my 04 RS on E85 with a IX turbo on 30 psi was 395hp, on a Mustang dyno. Uncorrected was 389.
Nice numbers! Did you mean 395 uncorrected / 389 corrected? Your corrected numbers should be the lower of the two.
Old Apr 19, 2009 | 09:07 AM
  #32
GRNCT9A's Avatar
Originally Posted by sEvoIXnTurboS2k
According to Mike @ AWD the boost will hold longer with an 02 dump and HP actuator. I will be getting both items to see if he is correct. He said the taper should be 3-4psi with those items, so if I ran 30psi I should see 26-27psi at redline if he is correct.
You probably wouldn't even need the O2 dump. Just the HP Actuator and turn the rod clockwise and turn your boost controller down at the same time. With my setup, I hit 27psi and taper to 25psi by redline.
Old May 13, 2009 | 10:40 PM
  #33
EvODavO's Avatar
Impressive. God I wish we had E85 in NJ.
Old May 14, 2009 | 10:28 PM
  #34
ssteve's Avatar
Originally Posted by sslevo
Wow, that would be crazy, from what i've seen a FP red will hold that but not a stock turbo. Let us know if it works though
Heres a 05 VIII turbo I ported for a customer I was doing some testing with. The graph shows right under 25psi but that was the final tune and backed off since it was a track car. The car held a little over 26psi with no taper. That was without an external dump or any other fancy mods other then porting, TBE, and Tune By Bryan at GST on a gm 3port with ecu boost control.
Old May 18, 2009 | 12:12 AM
  #35
mr.almeida's Avatar
Nice numbers this set up will be very ideal for me.
Old May 18, 2009 | 01:53 AM
  #36
Alan Szabo Jr's Avatar
Best I could get with my 04 RS on E85 with a IX turbo on 30 psi was 395hp, on a Mustang dyno. Uncorrected was 389. Tried everything to keep the boost from dropping to 22 psi. Best I can get it to hold is 23 psi at 7500. Stock motor. Cams. Stock intake and TB. BR exh, Race core, lower pipe. Stock upper. Pump, 1000's, ported manifold, Ebay O2 housing.
I have tested a few of the O2 dumps, four different heavy WG canisters. Regardless of what people advertise or claim. Have yet to see anything that will make a IX turbo hold 26-27 psi from a 30 psi peak. Turbo dies off up top period. Most cars drop to 20-21-22 if you are lucky.
This is very true.... Early Evo has also messed with my car as well on this. Mine made 392hp and 420TQ on 30psi on the MD on the stock IX turbo w/E85.
Old May 18, 2009 | 01:55 AM
  #37
Not in Las Vegas.... Our corrected number read higher due to being higher altitude. Dyno corrects for sea level.
Old Aug 9, 2009 | 10:30 AM
  #38
SLOWRREX's Avatar
Nice numbers..Im hoping to hit the 400 mark..when i switch to E85 here really soon..I cant wait..Wish i could switch today..Justin
Old Aug 9, 2009 | 10:55 AM
  #39
fqjdmct9a's Avatar
Congrats on new number....i been thinking bout switching to e85 but the closest pump its 30 min away and i dont know if i can do it twice a week maybe more
tscompusa
May 9, 2016 12:15 PM
ant_turbo
Feb 9, 2016 06:31 PM
tscompusa
Sep 13, 2014 11:05 AM
evil_eagle
Nov 16, 2008 12:37 PM
