question about tune...
Old May 7, 2009 | 07:55 PM
MattsT67's Avatar
I was recently tuned by Scott at TTP. I have typical bolt ons... made 355whp. I am installing an AMS FMIC, hard pipes, and a EPM open dump 02 housing..... Will I need a retune, or should i be ok until i get my cams installed. I will be getting tuned once my cams are in, but wasnt sure if i would be alright with the 02 housing
Old May 7, 2009 | 08:34 PM
TTP Engineering's Avatar
The fmic and O2 housing can affect your AFR. Furthermore your boost curve could change where peak torque lands in the RPM band and the ignition timing advance for that area might not coincide with what is safe any longer.
When are the cams going in?
Old May 7, 2009 | 09:02 PM
sekula's Avatar
I would let scott look at some logs after you put these parts on and log the car.
Old May 8, 2009 | 03:57 AM
FL_SilverEvo8's Avatar
To be on the safe side I would get a retune. FMIC you are going to flow a little bit more cooler air vs. the stock one. So yeah your AFR are going to be different. Re-tune it so it is balanced out and grab a few pony's while your at it.
Old May 8, 2009 | 05:31 AM
JakeTheVIII's Avatar
Or put everything on at once, then retune.
Old May 8, 2009 | 05:46 AM
EvoDom's Avatar
why not just wait until you put the cams in then re-tune with everything?
Old May 8, 2009 | 05:54 AM
gsrboi80's Avatar
Just log the car as stated and email the logs down to Scott. It shouldn't need too much adj. Best to always have the cars tune on par
Old May 8, 2009 | 11:42 AM
MattsT67's Avatar
alright, i guess ill be waiting
EVOWRC111
Jan 20, 2012 08:43 AM
dinok
Sep 6, 2010 06:32 PM
elphalba
Jun 24, 2008 07:37 PM
EvoRalph
Feb 28, 2008 04:03 PM
Cali2MDevo8
May 4, 2007 09:07 PM
